grid heater not working
Old Dec 30, 2015 | 04:10 PM
helifixer's Avatar
wait to start light only on with light test. does not stay on even at 15 degrees
no grid heat before start.
once it is running the heater cycles until engine warms up as it should.
no codes.
stars fine until cold soaked again. been getting down to the low teens at night.
2002 6 speed
all stock
Old Dec 30, 2015 | 10:13 PM
SIXSLUG's Avatar
Check batteries, once started alternator takes load to power heaters...
Connectors, ground wires etc.....
Old Dec 31, 2015 | 07:25 PM
helifixer's Avatar
IAT sensor. tested good but didn't work. changed it and now grid heater is working normally
Old Dec 31, 2015 | 09:58 PM
leathermaneod's Avatar
Thanks for updating the thread with your fix! Glad you got it worked out so quickly
Old Jan 1, 2016 | 10:35 AM
cougar's Avatar
Mine tested good, but was off by 20° causing the grid heaters and high idle to come on only when it was a lot colder than it was supposed to.
Old Jan 1, 2016 | 03:43 PM
SIXSLUG's Avatar
Good deal, I always start with the simple, easy stuff before going to my wallet....or the last thing I monkeyed with!!!
Riddler69
Apr 19, 2007 06:29 PM
lowwag64
Nov 26, 2006 08:08 PM
jellis
Oct 24, 2006 07:06 PM
trik396
Oct 14, 2006 06:33 AM
kw power
Dec 9, 2005 09:42 PM
