grid heater not working?
Old Nov 26, 2006 | 03:05 PM
lowwag64's Avatar
Hi again,I went to go fire up the truck this morning and my "wait to start" light and buzzer never came on.It's -25 deg. celcuis,but I had to go to work.So my truck struggled to get going,I noticed something wierd;when my wipers came on my radio would quit for a second?
I ran the truck all day with no problems.
My questions are did I melt a fusiable link,relay,or solenoid? The previous owner looks like he had done some splicing around the solenoids?
I was already in the "sticky" to get as much info before freezin my edit off today with a test lite.There was no "check engine" lite?
any advice?
Old Nov 26, 2006 | 03:12 PM
Was the truck plugged in?
Old Nov 26, 2006 | 04:05 PM
lowwag64's Avatar
it was plugged in for only 2 hours...it was very hard to start...today I've had it plugged in for 8 hours,checked it-no "lights" or buzzer?
Old Nov 26, 2006 | 04:34 PM
When the truck is plugged in the grid heaters are not likely to run. If the block heater can get the engine temp up to 59 F then they will not run.
Old Nov 26, 2006 | 04:49 PM
lowwag64's Avatar
I still think something may be wrong...I usually get a "wait to start" all the time.ever in summer.
it was a real bear to start,I'm sure i didn't do it any good?
Old Nov 26, 2006 | 05:06 PM
Oh, so the bulb check didn't even work. Was the battery charging?
Old Nov 26, 2006 | 06:41 PM
lowwag64's Avatar
yes,it was
Old Nov 26, 2006 | 08:08 PM
That's weird. The bulb check should work even if the IAT sensor is bad, and if the whole PCM was dead then the truck shouldn't charge. I can't say I'm sure what the problem is. I'd start by checking the IAT sensor (right behind the grid heater). If it's an open circuit or a dead short, it's bad. The resistance should change with temperature.
GIT-R-DONE
Aug 20, 2017 12:56 AM
Riddler69
Apr 19, 2007 06:29 PM
jellis
Oct 24, 2006 07:06 PM
trik396
Oct 14, 2006 06:33 AM
kw power
Dec 9, 2005 09:42 PM
