Transmission types--I need help
Old Apr 25, 2008 | 07:00 PM
Trace's Avatar
Question Transmission types--I need help
I just got a printout from the dealer (using my VIN) and it lists all the features that went into building of this truck. Right down to the date it rolled off the line.
Q: The sheet is showing I have a DDX 5-speed HD Manual Transmission
But, when reading the service manual for the correct lubricant, they show 3 types.
1) NV3500
2) NV4500
3) NV5600
How can I tell if which one I have on my truck?
Any recommendations on what to run for lube? The book shows its only as current as the printing... So.....
Old Apr 25, 2008 | 07:11 PM
blackdiesel's Avatar
Registered
you have the 4500
Old Apr 25, 2008 | 07:18 PM
Trace's Avatar
Originally Posted by blackdiesel
you have the 4500
How do you know? Not saying you dont, just wondering how is all....
Thanks,
Old Apr 25, 2008 | 07:49 PM
oaborbag's Avatar
The NV5600 is the 6 speed which you don't have, and the NV3500 was on the gasoline engines only on HD models, as far as I know.
Old Apr 25, 2008 | 08:17 PM
Trace's Avatar
Another Question
Would this truck have limited slip differential? Reading the service manual, replacing fluids with "fresh" and giving it a complete tune up you might say.
The service book is showing me the types of lubs to use in the following
Differential lubricant...
Limited skip differential...
Thanks
Old Apr 25, 2008 | 08:33 PM
Registered
Thanks,
because im a freakin genius
as for the limited slip, that could be in the glove box (on a label) could be on a tag under a bolt on the rear end cover or you could jack up your rear end and turn one wheel by hand. if the other turns the same way, its a limited slip, if it turns the other, is an open differental
Old Apr 25, 2008 | 09:02 PM
Trace's Avatar
Got it! Thanks!!
Glove box says "Axle Ratio 3:55"
Rear end cover only has some numbers.
Jacking up the truck in the past.....I remember then turning opposit directions...So, Im gonna say "OPEN DIFF" lol
Thanks again!
Old Apr 29, 2008 | 08:18 PM
TOM R's Avatar
on this topic i was wondering which auto trans I have? truck listed in signiture thanks
jonesm8
Jun 27, 2007 12:03 AM
HOHN
Mar 10, 2005 05:52 PM
greatwhite
Feb 4, 2005 07:44 AM
apache
Nov 9, 2003 02:19 PM
dhe9
Oct 26, 2003 10:47 AM
