Tranny Swap!!!!!
Old Feb 16, 2009 | 10:53 PM
Engineer18's Avatar
Tranny Swap!!!!!
Hey everyone i am having a little bit of an issue with converting an 2001 Dodge 2500 Extended cab long bed from an automatic to an manual transmission. The problem that I am having is the ECM. I need to know if an ECM change is need to convert to the manual transmission. I haven't done that much research on the issue but i was hoping to get the heads up from someone on the conversion.
Thanks
Evann
Old Feb 16, 2009 | 11:11 PM
98whitelightnin's Avatar
You might try using the search button. I know there are several people that have done this swap. I believe you have to get one from a manual truck but Im not sure.
Old Feb 17, 2009 | 06:56 PM
jdg4233's Avatar
I to want to swap trans but i want to go from a six speed to an auto so any info found would be great
Old Feb 18, 2009 | 02:49 AM
Were in east Tx are you at. Ive got a 98 with semi built auto in Chandler just outside of Tyler.
Old Feb 18, 2009 | 07:25 AM
jdg4233's Avatar
I live in Frankston
Old Feb 19, 2009 | 07:06 AM
Your right down the road from my folks house. Ive been to the DQ and ford house in Frankston.
Old Feb 19, 2009 | 10:08 AM
gmctd's Avatar
Each of you will need the module and wiring harness to match the transmission of choice - the transmission wiring harness disconnects from the main wiring harness - should also be a transmission control relay in the power center - fortunately, DCJ installed connectors for most options in the basic wiring harnesses - the manual conversion could work with the auto module, but will always DTC at each start - the auto conversion will not function with the manual module because the TCC, electronic governor, and overdrive is controlled by the corresponding module - if you use the 47RH or early 47RE, you could get by without changing modules, but the manual module could still generate several DTC's due to lack of gear-range inputs - best to use the correct module and harness - don't fergit the TPS\bracket\cable assembly - maybe you two guys should talk
Old Feb 21, 2009 | 07:43 AM
jdg4233's Avatar
I agree but there is one problem my truck is 2wd and his is 4wd
Old Mar 11, 2010 | 07:24 PM
brad ericsson's Avatar
im doing it the other way removing manual and installing auto. the transmission control relay in the power center- that you talk about -is that in the power control mod? i have the harness for the auto already
zethtays
Nov 3, 2010 06:24 PM
Black Dog
Dec 3, 2009 08:18 PM
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
