tranny leak...
Old Mar 12, 2006 | 09:37 AM
SuperDave4x4's Avatar
tranny leak...
Well my tranny decided to start peeing in the driveway. It's leeking from one of the aluminum tranny lines on the passanger side and is the one closes to the fire wall. From what I can tell is that it's leaking as if there is a bad oring or something. I checked the torq on the bolt to see if it had just come loose, but its tight as it can be. What could be problem be? Does anyone have part number for that aluminun line? Also I have a 99 and its supposed to have the upgraded lines. What does the upgraded one look like compared to the old one?
Thanks
Old Mar 12, 2006 | 09:54 AM
mini14's Avatar
www.rockauto.com has the lines if u need new ones. if its one of the lines going into the heat exchanger, they are compression fitting, no orings. orings leak on the quick connect fittings on the lines going into and outa the trans cooler in front.
Old Mar 12, 2006 | 10:56 AM
There are 2 lines that connect to what would be the heat exchanger I guess, that is right under the turbo and it is the line that is closest to the firewall. I was hoping that I could get the line locally as this is my only mode of transportation.
Old Mar 12, 2006 | 11:43 AM
J BODY's Avatar
Line from the trans, across the bottom and attaching to the heat exchanger (line furthest back, or closest to firewall as you describe) is the output line from the trans. I install them from time to time and find that the "seat" can crack where the line fits to the fitting on the heat exchanger. The line is available at the dealer for around $31.00, or you can spend about $129.00 on the 94/95 line that has the bung welded on it for a temp sensor. This line also has a short rubber section on it that I believe helps dampen vibration. Also, make sure you have all the plastic clips that hold the lines together. They run about $8.00 each, or you can fab some up using heater hose and zip ties.
Old Mar 12, 2006 | 12:20 PM
That's pretty much what Jeff Garmon told me last night at the track. But what I dont understand is my truck is supposed to have the upgraded tranny lines correct? Well then why are both my tranny lines COMPELETLY aluminum? There isnt a stich of rubber any where. Are these the lines that you are refering too? http://www.rockauto.com/ref/RB/Detai...p1/624-332.jpg Also what do these clips look like? Sorry for the newb questions, but I'm not too familiar with tranny stuff.
Oh also out of the 2 lines that are connected to the heat exchanger, the one that is leaking is the shortest one out of the 2. If that helps you on figuring out which line I need to replace.
Thanks for all the help guys. Yall are really saving me money by not taking it to the dealership.
Old Mar 12, 2006 | 12:26 PM
mini14's Avatar
the lines in that picture are for the in and out from the trans cooler located next to the radiator.....the dealer wants 129.00 for 1 line.
Old Mar 12, 2006 | 12:29 PM
Oh, ok. Thats not what I need then. I've looked on rockauto for the trans to heat exchanger line and cant seem to find it.
Old Mar 12, 2006 | 12:37 PM
mini14's Avatar
soory, but u can fab up some of your own, just go to plumbing supply to get correct flare fitting and a small length of hose to splice the original line, the dealer will ripe u if u get it from them.
Old Mar 12, 2006 | 12:57 PM
What kind of pressures should these hoses be able to handle? There's a place that makes hoses, tubes and what not. I think I'm just going to take the hose to them and see what they can do. I'd rather not have those aluminum lines any more and a better way of connecting them to the heat exchanger since this has happened once before.
Also J BODY, do you have a part number for that 31.00 line?
Old Mar 12, 2006 | 01:16 PM
mini14's Avatar
i believe 90 psi for a stock tranny, get some hydraluic hoses..
http://www.surpluscenter.com/sort.as...c&keyword=HH08 might have the hose with the fitting allready.
Old Mar 13, 2006 | 08:08 AM
Any other ideas anybody?
Black Dog
Dec 3, 2009 08:18 PM
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
