Is there anything new on a high idle??
Old Nov 23, 2004 | 12:45 AM
Haulin_in_Dixie's Avatar
I have not looked in a year or over, I now need to add a high idle before Christmas. Will be transporting a tropical bird in the truck and it will have to stay running.
What is the latest for the 24 valve? Really would like one that turns off and on with a switch, not a rheostat.
Old Nov 23, 2004 | 08:41 AM
BIGBADBOB's Avatar
Here is a bulletin on the cruise control one. It's probably already been here a few times.
http://www.portjeff.net/df5152/tsb_1800404.htm
Old Nov 23, 2004 | 10:43 AM
Dodge Demon's Avatar
So your saying that the cruise does control the high idle on all 24 valves,it just has to be enabled,I thouht the cruise thing only worked on the 3er gen, trucks,could someone clarify .
Old Nov 23, 2004 | 12:19 PM
farmer dave's Avatar
This works for autos, but what about the trucks with a stick?
Old Nov 23, 2004 | 12:34 PM
BigBlue's Avatar
A tropical bird? That's an interesting thing to be hauling.
Old Nov 23, 2004 | 12:46 PM
How big is the trailer for the bird?
It would probably like a ride in a cady instead.
Old Nov 23, 2004 | 01:51 PM
Mechanos's Avatar
As I read it, that Service Bulletin only applies to 2004 (DR) trucks, not the 2nd gen (BR) trucks. Someone correct me if I'm wrong.
Old Nov 23, 2004 | 04:13 PM
It is an African Grey. Carrying one is like haveing a spoiled three year old child with you. They do need stable temperatures though. Have a 24 inch cage for it in place of the back seat.
We had birds for many years, just decided to get another one. They are good company and unlike haveing the wife with you, just put them back in the cage
The Grey is good because of the short tail feathers, lot smaller cage.
Old Nov 23, 2004 | 04:29 PM
I use a eletric high idle solinoid from a gas carbourator,mounted it under that black plastic cover on the throttle linkage above the injection pump with a lighted rocker switch on the dash,actually works great,have it set for 1400 RPM ,just click the switch on,step on the foot pedal and it will set right on the 1400.The solinoid has an adjustment on it to set the RPMs anywhere you want.When your ready to go just click the switch to off and your back to 800 RPMs.Would like the cruise setup but looks like 2002 and down dont have the capability,Ill bet its in the program but Dodge in their wisdom used a 3 cyl. idle with only one speed setting,Cummins uses the cruise for idle adjustment.
Old Nov 23, 2004 | 04:58 PM
CJ's Avatar
CJ
I called the dealer the other day after reading on another forum about the high idle circuit enable. The service tech said it was available for my truck but it would not come on until -15deg F. Is this something different?
CJ
Old Nov 23, 2004 | 05:02 PM
Yeah,thats the one with the 3 cyl. that cuts out IF its cold enough out,kind of a chickencrap setup. Dodge??????
Old Nov 23, 2004 | 07:56 PM
CJ's Avatar
CJ
So this is an 03 and up thing?
CJ
Old Nov 23, 2004 | 08:11 PM
I may build my own. All I can find is $200 and it looks like all it is to make it work is a rehostat of the right ohms. If I do I will post the results.
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
Tom282
Nov 6, 2006 05:21 AM
Dodgezilla
Oct 25, 2004 11:28 PM
Shaders 24v
Apr 16, 2004 01:14 AM
