Swap questions and problems?
My block has a gnarly crack in it,just below the oil filter,I've got no idea how it got cracked,but the engines' broke now,I'm wondering.
1.Will any 24valve engine work,or do I need to get one in a certain year?
2.what do i need to look out for,cause' the last thing I need is to spend any more money than is nessasary,because of course I'm totaly strapped and could not imagine a worse time for this to happen.
3.Max HP is not my concern,need this one to last,thought I would get at least 500k out of my last one,but not to be
Anyways,sniveling aside....I'd sure appricate anything you all have to say,even if your just thinking out loud,cause I've gotta get this puppy up and roaring again soon!
Thanks guys/gals
Brian
Thanks guys/gals
Brian
Wow,no1 knows anything about what engine works in what truck? No idea of what to watch out for?
What mistake did I make in my thread to not get one response?
(something stuck in my teeth?)
I would look for another '01 short block if i was in your position, if all your pumps and such are in bad shape.. spring for a long block.. i suppose you could always "move up" to a CR engine but then you need a CR ecu and such
Thanks
And the VP-44 is HO also,although I'd heared that I did not have to use a HO pump,put a HO back on it anyway.
Thanks
Thanks.
Got another quick question,where can a guy find a cheap/good guage cluster,pillar mount is fine.
I've found a 2000 ram,with the "HO" and a 6 speed,so I'm not sure if my edge off an 01 will work,I'm guessing no,and I need to have gauges.
madhat
Nov 30, 2008 08:02 AM
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
