Surging Engine- VP44?
Old Jul 20, 2005 | 03:05 PM
Contractor's Avatar
Yesterday my engine started surging. Loping at idle when not under load. Fine at WOT.
Replaced LP today. Have 15 psi but the needle bounces with the lope. Is my IP shot?
Also, can I pull the codes myself on an 01?. Tried the trip odo thing to no avail.
Thanks in advance.
Cole
Old Jul 20, 2005 | 04:29 PM
crobtex's Avatar
Fuel Filter?
Old Jul 20, 2005 | 05:39 PM
Clunk's Avatar
Try turning your keyswitch on-off-on-off-on, that's 3 on's, then look at your odo.
Old Jul 20, 2005 | 05:48 PM
phox_mulder's Avatar
Re: Surging Engine- VP44?
That's what mine was doing when the VP44 died.
Never had any codes, didn't have guages at the time, but LP is still the original.
phox
Old Jul 20, 2005 | 06:11 PM
53 Block King's Avatar
Contractor,
TRY THE FUEL FILTER! Another member from here recomended it to me and I did it and NO MORE PROBLEMS. It is worth the shot.... It made my week for sure. I put a new lift pump on too and it still did it, then I changed fuel filter and NO MORE PROBLEMS.
Also check my post.... Engine surging
There are some other ideas there too
Best of Luck
Old Jul 22, 2005 | 07:01 AM
Contractor's Avatar
Well, I tried a filter and still had the issue. Pulled the codes with a scanner and there were none. A guy that works for me suggested a dirty injector, so I ran a can of BG 44K through it and it runs great now. Thanks for the help.
Cole
Old Jul 22, 2005 | 08:40 AM
MKELLY's Avatar
What is BG 44k I use power service (grey container) in the summer and the white in the winter. I'm having a surging issue as well would like to try this out. Thanks.
Old Jul 22, 2005 | 06:55 PM
Contractor's Avatar
It is manufactured by BG products in Kansas. Comes in a 12 oz can for around $ 20. It IMMEDIATELY solved the problem. I still have 1/2 tank of fuel to burn that I treated. Not cheap but good. Napa should carry it, or any performance store, probably not checker or auto zone. I don't know. My assumption is that I had a dirty injector or two. Good Luck.
Cole
dieselguy71
Apr 16, 2008 06:41 PM
dweller
Feb 28, 2007 04:08 PM
eedstrom
Aug 20, 2006 10:54 PM
hukk
Mar 25, 2004 03:56 PM
Voss
Feb 17, 2003 07:33 AM
