Surging - VP44 Symptom
Old Aug 20, 2006 | 10:47 PM
eedstrom's Avatar
Surging - Is it a VP44 Symptom?
started getting the dead pedal and code P0216 about a month ago on my 1999 2500 so I know my VP44 is going. I was running about 6psi between the filter and the pump so I decided to replace the lift pump with the Galcier Diesel GFS-392. Got that on at midnight last night (great kit!) and am running about 20psi at idle. On the test drive this morning I am getting surging at idle while in gear. RPM varies up and down about a 100 rpm. Seems fine at speed. Is this just another sign on an almost dead VP44 or did I screw something up in my GFS-392 install?
I bought a replacement VP44 from mwfi.com and am having a local shop install it this week - don't know if should risk driving the 20 miles to the shop.
__________________________________________________ ____________
99DCTD2500 Auto 4x4 3:54 Stock except K&N and GFS-392 lift pump kit
Old Aug 20, 2006 | 10:54 PM
runamuk's Avatar
This may help if you are mechanically inclined.
https://www.dieseltruckresource.com/...d.php?t=109032
alabama
Nov 4, 2007 12:51 PM
Hopper
Apr 13, 2007 04:43 PM
SuperDave4x4
13
Nov 22, 2006 09:33 AM
ET RAM
Oct 18, 2005 11:24 PM
