bad mount symptom but not bad
Old Nov 3, 2007 | 08:19 PM
alabama's Avatar
Cool bad mount symptom but not bad
i drive a 1999 dodge 2500 4wd. i've owned it for a year now. i have what feels like a broken engine or trans mount symptom. i have repeatedly checked for bad mounts no luck. when leaving from a signal if the accelerator is pushed for a normal take off there is a thud . it can be felt in the seat of my pants. also when cruising around 70 or so, if i let off the acceleartor there seems to be a noticeable backlash feeling. the u joints checked ok. is this normal??
Old Nov 3, 2007 | 09:33 PM
nickg's Avatar
How did you test for a bad mount? try a stall test with brakes applied and with the hood open to watch the engine twist, also slip joints will give a "thunk/snap" if they have play. and excessive rear end back lash will cause a noise too.
Old Nov 3, 2007 | 11:05 PM
dj_souvlaki's Avatar
check out myabe your u-joints and your tranny mounts as well would probably cause it. also a long shot check out your leaf springs were they mount on the axle. i've seen on other trucks them slipping as well as bushings.
Old Nov 4, 2007 | 12:45 PM
nickg's Avatar
As dj posted, loose U-bolts will give a wicked noise as the diff tries to rotate
Old Nov 4, 2007 | 12:51 PM
alabama's Avatar
thanks guys. i will check it out and let you kow what /if i find
Hopper
Apr 13, 2007 04:43 PM
SuperDave4x4
13
Nov 22, 2006 09:33 AM
eedstrom
Aug 20, 2006 10:54 PM
ET RAM
Oct 18, 2005 11:24 PM
