surging, engine code PPCU
Old Mar 24, 2004 | 08:45 PM
hukk's Avatar
I'm a new member and hoping for some information. I have an 01, ETH, 38K miles. Recently started surging a low speeds, not noticeable at higher speeds. I checked for codes and got "PPCU".
Can anyone tell me what this code is? Only mod to truck is Edge EZ. I changed it from highest setting to mid setting, no change. I have not tried with EZ disconnected.
Any help is greatly appreciated. Likely will take to dealer, but I want to know what the cause may be.
Thanks in advance.
hukk
Old Mar 24, 2004 | 08:50 PM
phox_mulder's Avatar
When you check for codes with the key on/off/on/off/on method the odometer should read:
P-ECU
P-PCU
P-DONE
If no codes are present.
If there were codes, they would come after the specific ECU or PCU.
I.E.
P-ECU
P- (insert code here)
P-PCU
P-DONE
Going by this, you don't have any codes present, that are readable with that method.
If you think you should see some codes, you'll have to get them read with an ODB reader.
Most big auto parts places will read them for free.
(expecting you to buy the new part from them right then)
Usually they aren't set up for the Diesel specific codes though, and you might get some misinterpretation.
Going by your sig, you seem to know your way around Diesels (unless maybe you bought it used with the guages already in place?)
Have you noticed a change in your fuel pressure?
Lift pump ever replaced?
Surging is usually a sign of the VP44 injection pump dying.
Mine suffered the low RPM surge, and the VP44 was replaced with 4,000 on the odometer, no codes were ever present.
phox
Old Mar 24, 2004 | 11:23 PM
hukk's Avatar
Thanks for the info on the codes. From what you indicate I need to recheck tomorrow but probably don't have any codes.
I bought the truck new and I installed the gauges and EZ at around 32K miles. At that point the lift pump was dead, replaced by dealer. In fact, I also added a mechanical FP pressure gauge under the hood to confirm that the electrical one on the A pillar was working correct after my install.
I have no idea how long I may have driven with the bad lift pump. Kind of worried that VP44 might have been damaged. Can the dealer usually diagnose a surging problem if it is the VP44.
Current fp is 14 - 15 at idle and down to 8 at full throttle.
hukk
Old Mar 25, 2004 | 03:56 PM
hukk
Depends on the Dealer.
Some are set up to properly diagnose the VP44, others are not.
I lucked out and the Dealer I took mine too was one of the few in my area that could.
Still had to wait about a week to get my truck back, after all the warranty hoops were properly jumped through by me, the Dealer and STAR (the Chrysler warranty people).
Good luck.
phox
53 Block King
15
Aug 30, 2020 05:12 PM
Red3quarter
0
Nov 23, 2010 02:56 PM
desertoy
Sep 10, 2007 06:32 PM
Contractor
Jul 22, 2005 06:55 PM
Voss
Feb 17, 2003 07:33 AM
