T-Case
Old Mar 25, 2004 | 09:25 AM
DODGE4X4's Avatar
T-Case
How much fluid is in the Transfer case? I'm going to change mine out and want to know how much ATF to buy.
Old Mar 25, 2004 | 11:36 AM
dodgediesel4x4's Avatar
Well not sure what t-case you have, but here check out this site:
http://dodgeram.org/tech/specs/tranfer_case.htm
You can check the tag on you t-case to see which one you have.
Keep on keeping on,
Hunter
Old Mar 25, 2004 | 03:46 PM
DODGE4X4's Avatar
Thanks for the help I forgot about that site My T- Case is a 241 DHD... I guess it is the 241 HD I don't see anything else that has the DHD on it.
Old Mar 25, 2004 | 04:25 PM
cmckinney's Avatar
I thought all the Diesel trucks received the 241HD transfer case.
-CM
Old Mar 25, 2004 | 04:49 PM
erics76's Avatar
It was an option on my '02
Old Mar 25, 2004 | 07:24 PM
44-40's Avatar
There are two styles 241 transfer cases used in the Dodges that I know of. there is the dhd and the lhd ( I hope I got that right). One uses a smaller slip yoke ( auto trans application), the other has a larger slip yoke (also auto trans application)measures about 2.2 in diameter. I ordered tail shaft bushing for mine twice because they sent me one for lhd and it was way to small. I dont know if all diesel applications use the dhd. Anyway the 241 dhd holds 3 1/2 to 4 quarts.
Old Mar 25, 2004 | 11:09 PM
DODGE4X4's Avatar
Thanks for the help 44-40
wyododge
Aug 18, 2011 07:48 AM
Timinva
Sep 3, 2004 10:15 AM
hw101
Mar 16, 2003 12:07 PM
Jbolt001
Oct 26, 2002 07:24 PM
