Starting Issues
Old Aug 21, 2009 | 07:37 PM
GreatTruck2001's Avatar
Starting Issues
I've begun to have an issue starting my CTD. After the truck is warm when I try to restart the truck I only get a click. No turning over, just a click, I hear the FASS run normally, the "wait to start" light goes off, but no turn over. I then wait a few seconds, go through the process again and she starts normally. Batteries are fine and engine charges fine. This happens very rarely, but it makes me worry. Any thoughts?
Old Aug 21, 2009 | 08:15 PM
Busboy's Avatar
The click you hear would be the starter solenoid moving, the fact there is no stater rotation is probably because of the solenoid contacts are bad. This is a fairly common problem and there are heavy duty ones available. I have the link somewhere but I couldn't find it. If you do a search on here for starter contacts I'm sure you'll find them.
Old Aug 21, 2009 | 09:48 PM
dozer12216's Avatar
Be sure and check batteries separately. Another member just put two starters on because of almost DEAD batteries. The contacts are very likely otherwise. No need to replace assy. Very little else ever fails. JMHO
Old Aug 21, 2009 | 11:32 PM
PChouinard's Avatar
I second the starter contact change! Easy to do and saves you a ton of cash.
Safety first, remove both neg clamps before starting work or you'll be welding wrenches..
Old Aug 22, 2009 | 09:23 AM
duster75's Avatar
http://www.fostertruck.com/dodge/default.htm LarryB's starter fix solved my starter issues........
Old Aug 22, 2009 | 10:14 AM
Silver R/T's Avatar
Get them on ebay, they were like $20
Old Aug 22, 2009 | 10:16 AM
Silver R/T's Avatar
https://www.dieseltruckresource.com/...84#post2461484
Old Aug 24, 2009 | 01:23 PM
Thanks for the responses. Batteries are new and strong, so I believe it's the worn contacts. Is the rebuild something someone with low to mediim skills can handle? I'm not a professional mechanic, but I'm good at taking things apart and putting them back together if they are simple.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Contractor
Oct 11, 2005 07:23 AM
FastSS
Oct 11, 2004 02:57 PM
