Still engine issues! Cranks for hours before starting
Old Oct 6, 2004 | 03:37 PM
FastSS's Avatar
So the other day I hit my remote start and started to walk back down to my room... I noticed that it sounded kinda funny and I come to realize that its not running, its cranking! finally about 5 seconds later it fires...
all day yesterday its fine, first start of the day today and its the same thing, long period of cranking and it finally fires and runs ok
always seems low on power, builds boost just fine runs around 14-15psi of fuel pressure
Brand new LP and Wildcat maxflow kit
any ideas?
Old Oct 6, 2004 | 03:52 PM
MCummings's Avatar
Either you are loosing prime, loosing the injection, or the batteries are going out...
How long has the maxflow kit been on?
Is the truck hard(er) to start when hot? Do you ever get "dead pedal"? More than normal smoke? or extra smoke on startup, and cold idle?
Is your remote start waiting for the grid heaters to cycle?
Merrick
Old Oct 6, 2004 | 04:04 PM
FastSS's Avatar
seems like more smoke than normal on startup, yes its wired for grid heaters, and its getting down into the 40s at night with 60s at time of start.
no dead pedal, fires up like normal after first start... maxflow and lp have been on since aug 1 with maybe 1000 miles
Old Oct 6, 2004 | 04:27 PM
HOHN's Avatar
This sounds all too familiar.
Try parking with the truck pointing downhill. I bet this makes it different.
I've had a sporadic hard-start problem that is seems to surface only in cold weather. My truck will lose prime if it's sat for a while.
With the nose high, it loses prime every time, and you'll have to crank it a while.
With the nose low, it keeps prime.
I have an air leak somewhere, but I have no idea where. For a while, I was also experiencing a pressurized fuel tank, too (injector copper washers were leaking compression pressure into the fuel return). I don't have the pressurization any more, but still have an air leak that lets the truck lose prime.
It's weird how it only does it in colder weather.
Perhaps it's an O-ring at the injector line?
Justin
Old Oct 6, 2004 | 10:54 PM
FastSS's Avatar
you know its funny... my driveway has probably a 35* slope to it... nose up
Old Oct 7, 2004 | 08:29 AM
gamiller31's Avatar
I would check all the connections on the Max Flow kit. They were a real pain to get tight enough to not leak.
Old Oct 7, 2004 | 10:44 AM
FastSS's Avatar
indeed they are =(
funny how it only started doing it a day or two ago and hasnt done it before
Old Oct 7, 2004 | 11:27 AM
Ryan's Avatar
It Sounds to me like the grid heaters are not being given enough time to fully cycle.
Old Oct 7, 2004 | 01:42 PM
ramlovingvet's Avatar
DTR'S Chaplain
If you have even a very minor fuel leak on the return it will do that.
Old Oct 7, 2004 | 11:45 PM
duner's Avatar
does the remote system "wait to start" or is it made for gassers? just a thought
Old Oct 8, 2004 | 12:44 AM
FastSS's Avatar
Yes the remote start does wait to start, and I dont think the grid heaters are even needed at 60* ambient temp... just a thought
A fuel leak might also explain my misserable gas mileage
Old Oct 8, 2004 | 08:20 AM
MCummings's Avatar
Ahh, young gwasshoppa,, you come long way in short time.
Merrick
Old Oct 11, 2004 | 02:57 PM
FastSS's Avatar
update, im now below 10mpg and I have found that a leak does exist... one of my lines is DRIPPING diesel fuel, its a pretty hardcore leak.
Looks like I probably screwed up my fuel pressure gauge/maxflow install and I KNOW the fuel filter housing is REALLY messed up
looks like good times
FirstDiesel1955
Feb 22, 2013 11:24 AM
Dirk5.9
Jun 20, 2010 12:02 PM
elirandolph
Jun 8, 2009 01:31 PM
screaminbanana
Aug 25, 2005 09:30 AM
bigbaddiesel
21
May 21, 2003 11:17 PM
