overboost code truck falling flat on its face
Old Feb 25, 2007 | 02:24 AM
IntakeRacing's Avatar
i'm getting i think its p0234 (? bad memory) but its the overboost code. and when i start to wind up boost wise the truck feels like it falls flat on its face during acceleration. is there a way to stop the truck from shutting me down cause tahts what i'm assuming its doing?
Old Feb 25, 2007 | 06:47 AM
dieselbeef's Avatar
Muted User
torqgard???
Old Feb 25, 2007 | 07:33 AM
Hillcountry's Avatar
I don't know much about codes, but that's what it feels like when the MAP sensor goes bad...a little acceleration...then it flatlines...I hope that is it because you can get replacements at most auto parts stores.
Old Feb 25, 2007 | 08:21 AM
Copenhagenjunkie's Avatar
Yes that is the over boost code. That's not a bad thing either. It is basically telling you that you are boosting over computer controlled limits. You need a boost fooler if the va doesn't have one or has quit working.
Not sure about the falling flat on it face though.
Old Feb 25, 2007 | 11:34 AM
nitrousn's Avatar
Free up the wastegate. Its most likely stuck and causing the overboost and defueling.
Old Feb 25, 2007 | 03:32 PM
Tate's Avatar
Need a boost fooler of some sort. I like the Smarty, but I think BD sells one for $60 or so (don't quote me on that, though). Could always get a Comp, boost fooler AND extra power.
Old Feb 25, 2007 | 05:26 PM
phox_mulder's Avatar
Originally Posted by IntakeRacing
2001 Dodge 2500 slt diesel - va box, e/i, 3" lift, 35" m/t, bd 130hp injectos, bd super single b.
Doesn't that VA box have a built in boost fooler? sounds like it's gone bad, or has a bad connection at the MAP sensor.
Or, could be a bad MAP sensor, not giving enough signal for the boost fooler to realize there's any boost being made.
phox
Old Feb 25, 2007 | 10:09 PM
wastegate isn't jammed i checked it and its an aftermarket turbo.
its a really old v/a chip that just plugs in behind the injection pump (is that the map sensor plug in people are talking about) and if it was the map sensor shouldn't there be one other code?
also without a boost fooler would it cause it to stop boosting? or stop fueling?
and i'm looking into getting hte tst pm3 for a stacker would that fix it?
Old Feb 26, 2007 | 12:42 AM
Tate's Avatar
The MAP sensor is at the back of the head, just ahead of the IAT sensor. If the VA doesn't plug into it, then its not boost fooling. When the ECM sees an overboost condition, its supposed to pull fuel back until it comes back down. I'm pretty sure a TST is a boost fooling box. If it plugs into the MAP sensor, good chance its a boost fooler.
southpawslingr1
Aug 31, 2010 05:32 PM
223 rules
Apr 19, 2010 07:00 PM
jiggerman78
Oct 24, 2008 07:06 AM
JohnP
Nov 16, 2006 11:01 PM
HOdiesel80
19
Jun 10, 2005 08:38 AM
