Oil usage between changes
Old Jul 8, 2007 | 11:51 AM
SIXSLUG's Avatar
Just wondering how much oil usage you guys w/ 24v HO's are using between changes? I'm eating about 1 quart every 4-5K miles. No leaks, just the puke bottle. Thanks.
Old Jul 8, 2007 | 12:20 PM
jj3500's Avatar
i have the same truck. My oil is good through till next oil change. Puke bottle is gone and routed to the ground.
Old Jul 8, 2007 | 01:14 PM
lovinCTD59's Avatar
About 1/2-1 quart at around 3,000 miles. But I need a new drain plug, im leaving a wet spot of oil about the size of a football everynight.
Old Jul 10, 2007 | 03:01 PM
SIXSLUG's Avatar
I'm just interested in how much I am losing to burn off. This is my first diesel and it seems to use a little more oil than my gasser's have between changes. I though my chevy's was using alot for a brand new vehicle. Turns out the dealer was only putting 5 quarts in it at every change, it takes 6! I only went there because they offered the first two years of service free. Not anymore though.
Old Jul 10, 2007 | 03:45 PM
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
How many miles on the engine? I have the SO with 204,000 and don't burn any in between oil changes of about 5-7k
Old Jul 10, 2007 | 03:55 PM
scout98's Avatar
Well I am using to much then. I am adding 1-2 qts every 4-6 hundred miles most seems to be comming out the breather hose What could that be?
Old Jul 10, 2007 | 04:04 PM
qwest's Avatar
3/4 qt in 6000 miles. 70K miles on truck NO leaks or blow by at vent
This is the best oil usage yet, bought it with 50K miles,
was getting about 3.5-4k on a qt....
? just getting broken in???? or removing puke bottle ?
MPG is up also...
Old Jul 11, 2007 | 02:57 PM
SIXSLUG's Avatar
67,000 now. I just turned over for an oil change and checked to see and was surprised to see it down about a quart on the dipstick. Sitting cold flat and level.
Old Jul 11, 2007 | 03:22 PM
coachgrowl's Avatar
133,000 and I am not adding any between changes. Changing every 3k though so who knows. slight blow by coming out of the rerouted line for the puke bottle. I ran it under the tranny so I can smell it when idling.
Old Jul 11, 2007 | 03:24 PM
coachgrowl's Avatar
Oh almost forgot my truck seems to be very sensitive about being perfectly level. Seems almost a quart difference between my driveway and the street.
Old Jul 11, 2007 | 11:55 PM
nickg's Avatar
Mine was leaking after removing it, it was broke on the inside almost all the way around, from being over tightened, I could see it leaking near the hex, not around the gasket, I'm very lucky the head never popped off!! a trip to the dealer and 20$ later I had a new gasket and plug.
Yours might be in the same condition, you cant tell its broke till you remove the gasket
Old Jul 15, 2007 | 03:30 PM
SIXSLUG's Avatar
I just put a Femco drain plug on my truck. I have the usual grimy puke bottle and timing cover and some on the dampener. I clean it off at every change and it always returns. Never a drop on the ground though. I agree w/ coachgrowl about the finicky level spot. Mine reads about a quart lower when on my driveway than the actual reading when level.
Old Jul 15, 2007 | 06:16 PM
m.rehme's Avatar
I have 309,000 on my 1999. I change oil every 25,000 miles,
Usually need a quart around 12-14,000 miles and is good to go till oil change time.
dogcamo
Sep 27, 2007 04:32 PM
mr. ed
Jun 22, 2007 06:46 PM
PZM123
Feb 27, 2006 10:27 AM
tfarmer96
Mar 23, 2005 11:06 AM
blackdevil
Oct 24, 2004 07:55 PM
