Oil usage between changes
Just wondering how much oil usage you guys w/ 24v HO's are using between changes? I'm eating about 1 quart every 4-5K miles. No leaks, just the puke bottle. Thanks.
i have the same truck. My oil is good through till next oil change. Puke bottle is gone and routed to the ground.
About 1/2-1 quart at around 3,000 miles. But I need a new drain plug, im leaving a wet spot of oil about the size of a football everynight.
I'm just interested in how much I am losing to burn off. This is my first diesel and it seems to use a little more oil than my gasser's have between changes. I though my chevy's was using alot for a brand new vehicle. Turns out the dealer was only putting 5 quarts in it at every change, it takes 6! I only went there because they offered the first two years of service free. Not anymore though.
How many miles on the engine? I have the SO with 204,000 and don't burn any in between oil changes of about 5-7k
Well I am using to much then. I am adding 1-2 qts every 4-6 hundred miles most seems to be comming out the breather hose What could that be?
3/4 qt in 6000 miles. 70K miles on truck NO leaks or blow by at vent
This is the best oil usage yet, bought it with 50K miles, was getting about 3.5-4k on a qt.... ? just getting broken in???? or removing puke bottle ? MPG is up also... |
67,000 now. I just turned over for an oil change and checked to see and was surprised to see it down about a quart on the dipstick. Sitting cold flat and level.
133,000 and I am not adding any between changes. Changing every 3k though so who knows. slight blow by coming out of the rerouted line for the puke bottle. I ran it under the tranny so I can smell it when idling.[duhhh]
Oh almost forgot my truck seems to be very sensitive about being perfectly level. Seems almost a quart difference between my driveway and the street.
Originally Posted by lovinCTD59
(Post 1589136)
Mine was leaking after removing it, it was broke on the inside almost all the way around, from being over tightened, I could see it leaking near the hex, not around the gasket, I'm very lucky the head never popped off!! a trip to the dealer and 20$ later I had a new gasket and plug. Yours might be in the same condition, you cant tell its broke till you remove the gasket |
I just put a Femco drain plug on my truck. I have the usual grimy puke bottle and timing cover and some on the dampener. I clean it off at every change and it always returns. Never a drop on the ground though. I agree w/ coachgrowl about the finicky level spot. Mine reads about a quart lower when on my driveway than the actual reading when level.
I have 309,000 on my 1999. I change oil every 25,000 miles,
Usually need a quart around 12-14,000 miles and is good to go till oil change time. |
