sometimes low boost
sometimes low boost
I was pulling about 4000#s last weekend cruising at 50 mph when I hit the go go pedal a bit to go up a hill the truck slowed about 10 mph no matter how far I put the pedal down. My egt s would climb from 850 to 1050 but my boost stayed at 10 psi. Fuel pressure would not go below 6 psi edge was on #2, no noticable smoke, air filter is clean, iat map and coolant sensors have all been changed and I have no codes. I know my problem is with low boost what could be the cause?
From the air box I pressurized the intake system (40 psi) and plugged the side that goes onto the housing and I could not find any leaks. I put a new waste gate actuator on it about a year ago, and it still looks in good shape (no rust). I might try the turnbuckle thing on it since I can watch my boost now from the edge monitor
Clean the Map sensor, I read you have a K&N filter. Sometimes the filter oil covers the Map sensor with a film. The Map sensor in conjunction with other sensors control boost. This is a no cost troubleshoot.
MP
MP
stanbnv
Jul 5, 2011 11:10 AM
The_Head
May 10, 2011 06:20 PM
Beast2B
Dec 8, 2009 01:44 PM
mr300x11
Oct 11, 2007 08:46 PM
Dave88LX
Mar 2, 2007 04:23 PM
