Oil Pressure Guage
Oil Pressure Guage
I just wanted to make sure that the pressure gauge is NOT supposed to move unless the truck is cranked. Mine will go up to 75 lbs when I turn the key on. Any idea?
Your gauge will shortly start dropping out while driving down the road. This causes the PCM to scream about looking at the guages.
Procedure to replace the sending unit is a bit crazy. Its best reached by hand from underneath to unclip the wiring, and from the wheel well with a 4' extension and swivel to actually remove it. Installation can start by hand from underneath the truck, then use the extension to tighten it up.
jrs_dodge_diesel
Jun 23, 2010 10:43 AM
mytrucksaslug
Dec 16, 2007 01:11 PM
jgiachino
16
Jul 11, 2007 07:33 PM
GlennRMK
May 24, 2007 10:46 PM
bigragu
Jan 24, 2006 11:16 AM
