Oil Pan Leak
Old Jan 7, 2009 | 12:03 PM
TEXAGS'98's Avatar
Question Oil Pan Leak
Have a slow leak at the rear of the oil pan. Can I retorque the bolts, or is that not a good idea. I read that a new gasket is a real pain. Thanks for the help.
Old Jan 7, 2009 | 12:20 PM
John Faughn's Avatar
Not on what the gasket is made out of , but just tightening could just squeeze out more of the gasket .
As for replacing , it should not be that bad , you only need to drop the pan a couple inches , removing the pan , is a big job , just tedious , get very clean .
Old Jan 7, 2009 | 01:19 PM
dozer12216's Avatar
Try torquing. Could it be the dipstick connection on left side of engine, hidden of course. If a small seep, leave er be.
Old Jan 7, 2009 | 01:35 PM
Haulin_in_Dixie's Avatar
Not saying that this is the problem but these pans have a tendency to crack at the pan rail. so look it over real good or you do all this for nothing.
Old Jan 7, 2009 | 03:34 PM
smokinram99's Avatar
this can help if you pull off your pan: http://www.dodgeram.info/tsb/2001/09-006-01.htm
Old Jan 7, 2009 | 04:22 PM
dkenny's Avatar
I just changed the pan in my truck..rusted through..
It wasn't actually that hard. the place I went to had a guy who could weld so it was easier to cut the cross member out and weld it back. too about 3 hrs total.
it took longer to change the oil in the tranny..I broke one the bolts, drilled it out, tried to retap..then broke the tap.
-dkenny
Old Jan 7, 2009 | 05:15 PM
TEXAGS'98's Avatar
Thumbs up
Thanks for the help guys. I'll try tightening the bolts this weekend. Does anyone know the torque numbers on the bolts?
Old Jan 7, 2009 | 09:13 PM
Don't need a lift either, just flip it on its side, fix it!
Old Jan 7, 2009 | 11:44 PM
nickg's Avatar
All mine were loose, Just snugged then up by hand, that was 80,000+ Kms ago, no leaks since, very common with engine vibration for bolts to back off
tex23455
Jul 25, 2007 02:31 AM
bostongsx
Sep 25, 2006 11:25 PM
lovinCTD59
Aug 5, 2006 03:01 AM
Haulin_in_Dixie
Jun 1, 2005 09:59 PM
Ian
May 4, 2005 07:05 PM
