Oil leak behind PS Pump on a 2001
Old Nov 19, 2007 | 08:29 AM
JARHEAD's Avatar
My friend has a 01 and it has that leak that is behind the PS pump. ALmost positive it is oil and not PS fluid. I heard that it is an easy fix. Anyone got info on that???
Thanks
Kip
Old Nov 19, 2007 | 10:10 AM
hamilton71801's Avatar
It's the vacuum pump that's leaking and yes it's easy. You can get a seal kit for @10 that comes with instructions and takes about 3 hrs to do. Be sure and pull the PS pump and vacuum pump as one unit because it's hard to get everything lined back up if not. This is where I got mine http://hoeslidiesel.com/store/
Old Nov 19, 2007 | 05:22 PM
Lenn's Avatar
It very well could be your power steering pump. I had my vacuum pump sealed a year ago July. You could see the oil between the vacuum pump and power steering pump. My power steering just took a dive. It leaked bad at times and it looked like dirty crank case oil. They use transmission oil. It works fine now. I have to take it in after 5000 mi. to have it flushed out again. It was really dirty before.
Old Nov 19, 2007 | 05:25 PM
scottsjeeprolet's Avatar
Here is a place a lot of us have gotten the kit from.
http://www.fixinrams.com/
there are also people selling the kits on Ebay.
Old Nov 19, 2007 | 05:35 PM
Sunir's Avatar
Scott hey what's up bud...nice website...
I'm leaking ps fluid as well...one shop said it was the steering gearbox, still it may be the ps pump dunno yet...Len and I drove it around and the truck was making aweful noises so it seems like it's in the ps system... do you think it'd be wise to do the vacuum seal kit above at the same time...?
Old Nov 19, 2007 | 06:40 PM
Need to determine if it is the PS pump or steering box. then get a reman unit and do the seal too if it is the pump.
Old Nov 20, 2007 | 02:49 AM
OUTDOORSMAN's Avatar
I used the kit from fixin rams. It worked perfectly and the help the video gave and the provided tools was well worth it for me. I reccomend it. good luck with it, pretty easy job. toughest part was getting big hands in the tight places.
Old Nov 20, 2007 | 11:33 AM
JARHEAD's Avatar
Thanks for the replies. Looks like we will get on it as soon as the truck can be still for a day.
Kip
thesheriff
Aug 14, 2012 04:40 PM
jaconst
May 6, 2010 11:21 AM
djbikeman
17
Jan 31, 2006 09:31 PM
4x4
Dec 31, 2003 10:37 AM
bigbaddiesel
Mar 6, 2003 01:26 PM
