oil all over under engine
i was wondering if anyone has the same problem i do, there is alot of oil residue mixed with dirt and whatever else is underneath there. i can not find any major leaks on the engine. the front and rear main ive heard usually leak. just wondering why the is so much residue. any advice
Is there a good fix for the front or rear seals going without dropping the motor? Mine is gunky under there too. Some of it is p/s leakage but not all.
I assume that's a "take it to the shop" situation, but if I can limp it until I get the REST of this truck's issues sorted...
C
C
And bleeding the P/S system of air? Also, was told by local NAPA dude that chrysler likes ATF+4 as Power steering fluid. The manual says "mopar" fluid, and the back of the ATF+4 says it MIXES with Mopar... good?
I need to do this to install my redhead steering gear today, and if I tackle the vaccuum seal at some point the same will need to be done.
NickBeek
05-02-2008 08:41 PM
Tank_66
18
12-31-2006 02:15 PM
