new pumpgood boost no acceleration
Old Dec 15, 2006 | 04:55 PM
biododge1's Avatar
recheck for codes, if you have ether 'engine sync error or static timing error' the pump keyway has been installed backwards. keyway faces the rear of pump. the pump timing is matched to pump keyway. be sure the three digit # on keyway matches the 3 digit # on pump. there are 21 different keyways available. if found to be correct, check that the timing marks are lined up on the crank, cam, and pump. hope this helps.
Old Dec 15, 2006 | 05:47 PM
tookmyname's Avatar
no boost leaks the leak i've pinned down to behind the ip pump and i definantly need a fuel pres guage i'll let everyone know how it turns out any suggestions on accurate guages autometer pro-lite is what i've been using and where is the best place to get the reading
Old Dec 15, 2006 | 08:11 PM
ratsun's Avatar
The top of your fuel filter housing has 2 plugs the one forward is post filter and the one to the rear is pre-filter IIFC
Old Dec 15, 2006 | 09:59 PM
ramroamer's Avatar
I too lost low end power with the install of new vp, sucks, had to get a box to make me feel like the truck was still the beast I first bought. Dealer said no codes, no fix. So I juiced it!
Old Dec 15, 2006 | 10:30 PM
torquefan's Avatar
Originally Posted by tookmyname
the shop is a fairly reputable they said the keyway shifted on the old pump
I've seen a couple of early VP44s that tried to seize up and tore the key partially out of the shaft keyway. That's probably what they saw.
Old Dec 16, 2006 | 04:52 AM
AlpineRAM's Avatar
Well the 47RE has no 1st gear band. It's 2nd gear.
Slipped timing with a VP44- yes if the pump seized up for good but will set a code.
A low stall converter and a bigger turbo will always have a lot more lag than stock.
Is your pyro mounted pre-turbo? If yes I'd check the pyro because 400-600 sounds way too low. If it's accurate you can use a scanner to read out some values like the MAP and look if the ECM sees boost or not. The stock ECM can't fuel if there's no boost and if theMAP is dead it won't see the boost it has.
HTH
AlpineRAM
Old Dec 16, 2006 | 09:33 AM
nitrousn's Avatar
You need a fuel pressure guage now. Without fuel you cant make boost and the pyro readings will stay low. You also will kill another vp44 if thats the case.
Old Dec 16, 2006 | 06:09 PM
tookmyname's Avatar
my pyro is after the turbo 2"inside and 4"down pipe are there any tricks to help build boost quicker thanks guys for all the input i"m so glad i found this room
toddbweaver
15
May 17, 2020 05:52 PM
ImagesThatSing
Jul 27, 2006 05:41 PM
bigbaddiesel
Jan 24, 2003 12:37 AM
q40
Dec 14, 2002 12:08 AM
crobtex
Oct 8, 2002 11:28 AM
