Boost drops to 0 during acceleration
When I accelerate hard the boost will climb immediately to between 15-18 lbs of boost and then drop to 0 until I let off the throttle completely. I'm guessing that I have a bad waste gate. Is there a way for me to be sure? When truck was running right about 2 months ago it would climb right up to between 35-38 lbs. at full throttle.
Thanks
Todd
Thanks
Todd
is your gauge mechanical or is it plugged into the map sensor. if it is plugged into the sensor the sensor could be bad. that would also cause the truck to run back and not show any boost.
danny
danny
I have a mechanical guage, there is a pop and it drops to 0 on the guage and there is no power and the EGT's start to climb very quickly. If there was a leak I would expect that the power would be reduced all the time which it isn't. That's why I didn't know anything was wrong with the truck until I punched it to the floor and it took off like normal until the boost hits about between 15-18 pounds and then boom back to 0.
Leaks can work in mysterious ways...might be with enough boost whatever is "popping" releases pressure then "reseals" itself when you lose pressure...not saying that is what it is, but that's definetly where you should start.
I did some more testing on the interstate. I could ease the boost up to about 30 lbs when it would pop and go to 0. It's possible that the mechanical guage doesn't respond fast enough and it's really popping at around 30 lbs. I will try to get a good look under the hood in the next couple of days.
Thanks for all your responses
Todd
Todd
