new pumpgood boost no acceleration
i've got a 98 24v with an hx40 4"straightpipe 4.10gears and a tranny from a local shop with a lower stall it seems that i've lost my low end to about 35mph seems as if i'm not building boost quick enuff the shop that did my pump said it was timed wrong i bought the truck used and have put 50000 on it all my upgrades have been done within the last yera and a half
Welcome to the DTR!
I am pretty sure that your pump VP44 is timed electronically. Not like the ole 12v motors. that's why we add timing box's to the 24v's. I think the tranny shop should stick to tranny's.
I'm sure someone will chime in about the boost problem. Maybe too much air for the stock injectors and not enough fuel. A Smarty might cure it?
Sounds like a load to me?
Only way a pump can slip on a 24v is if the key breaks and would doubt that happened. You need to see what your FP to the IP is before you can go any farther. I am assuming you have changed the FF recently?
U can't check timing, it electronic and can only be changed with a fueling box. To me your boost seems low, I wonder if the wastegate is stuck partially open? What do you think members.........
the tranny is one taer old the problem started after the i.p pump install
i just reset the apps and that didn't work but i did find a leak i'm trying to track down it seems to only leak when your in the pedal
A boost leak?
The Edge Juice with Attitude is very good box with gauges and lots of safety features, best bang for the buck.
