white smoke under acceleration
Old Jan 20, 2003 | 05:31 PM
bigbaddiesel's Avatar
I adjusted my valves today (they were all a little to tight) then went for a drive. I see a lot of white smoke when i step on it while i am already moving down the road. Ive never noticed this before. It blows a little puff of black when i take off from a standstill. I am trying to improve my mileage (13.3 mpg) so i will be taking her to a shop to get timed. I also read about checking the overflow valve. What do ya check for? I guess this is a lot of questions for just one post. Anybody have any ideas?
Old Jan 21, 2003 | 05:14 PM
Re:white smoke under acceleration
thanks for responding and telling me the info. sounds like mine is probably fine since i have none of your symptoms. This is one less thing to worry about needin to get fixed.
Old Jan 22, 2003 | 12:37 PM
Paul Winey's Avatar
bigbaddiesel:<br><br>I had a similar problem - low power at take off and poor fuel mileage. No smoke problems, all stock settings. They found low fuel pressure, replaced overflow valve and had timing set to 16 from 14. I'm picking it up tonight. Can let you know the difference. Should see more low end power and better mileage. You may want to check this out yourself. Can't tell if you don't look.
Old Jan 24, 2003 | 12:37 AM
so howd she run after the work was done? I need to get my timing checked i think
superman
Mar 14, 2006 05:41 PM
JARHEAD
Nov 21, 2005 07:27 PM
2500Ram
16
Oct 17, 2005 03:43 PM
LDean
Feb 28, 2005 09:56 AM
