producing white smoke at slow acceleration
Old Feb 25, 2005 | 06:09 PM
LDean's Avatar
Question producing white smoke at slow acceleration
My truck is producing alot of white smoke during slow acceleration. i can accelerate fast and white smoke clears up. my truck is a 12v 1998 5sp
Old Feb 26, 2005 | 08:41 AM
Copenhagenjunkie's Avatar
Good, you found this place. Sorry for the wrong address.
Fellow Members HELLO, I sent this guy here and he needs some help.
Old Feb 26, 2005 | 09:47 AM
spunbearing's Avatar
Sounds like injectors or pump timing to me. Maybe someone more knowlegable will pipe up here soon.
Old Feb 26, 2005 | 10:31 AM
phox_mulder's Avatar
Not a whole lot of familiarity with the undervalved, but sounds like the timing slipped a little.
phox
Old Feb 26, 2005 | 12:04 PM
4doogie's Avatar
Or your turbo intercooler boot could be loose. Normally when this happens you loose power though. Welcome to the site, hope can help. Nice truck, if you get a chance fill out your sig, so we know exactly what you have. I see you said 98, 12v 5 speed, thats a great rare truck, best of luck with the problem.
Old Feb 27, 2005 | 02:07 PM
mr T's Avatar
need more info...does this happen when cold only? or clears up after the truck is warmed up?...when was the last time you changed your fuel filter? and check you fuel lines around the fuel filter for air/fuel leaks?
Andrew
Old Feb 27, 2005 | 08:04 PM
LDean's Avatar
No not only when its cold but it is worse when the motor is cold it will smoke and sputter for about a block. but when its warm it usually only does it in first gear when you first start to accelerate.
Old Feb 28, 2005 | 12:42 AM
P.O.R.'s Avatar
have you replaced the over flow valve, here is a link with symptoms..,
http://www.dodgeram.org/tech/dsl/tro...p.htm#Overflow
Old Feb 28, 2005 | 09:56 AM
infidel's Avatar
The overflow valve is the single part that wears out most on a 12 valve and is always a good place to start. 5 minute, one wrench job to replace it.
You won't find a better price than here
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
$35 + $7 shipping and handling.
RickG
Nov 6, 2008 07:33 AM
superman
Mar 14, 2006 05:41 PM
JARHEAD
Nov 21, 2005 07:27 PM
2500Ram
16
Oct 17, 2005 03:43 PM
bigbaddiesel
Jan 24, 2003 12:37 AM
