white smoke under acceleration
Old Mar 14, 2006 | 12:54 PM
superman's Avatar
Yes I searched. I've been searching for truck since I had to sell my 3rd gen (divorce).
A good friend of mine owns a used car lot and is at an auction right now. he's got a 1999 24 valve 5 spd. Can't tell exactly how many miles are on as the odometer looks to have been shoved part way over and you can't read the 6th digit (or 1st digit)...but it would stand to reason it's 135,000 (maybe 235,000)...he can read 35,xxx on it.
It has what looks to be a brand new turbo.
He says the truck cranks and idles fine. But when you hit the accel pedal it puffs a big puff of white smoke. It clears right up and there's no miss or anything. It does this under acceleration also...when you give it throttle it puffs a big puff of white smoke but clears up right away. It cruises just fine and doesn't smoke when at constant speed.
What could I possibly be looking at if something's wrong? Granted the truck is/was not warmed up so.....
Old Mar 14, 2006 | 02:45 PM
Mechanos's Avatar
Light colored smoke (kinda of a light pale blueish color) out of a cold engine is incomplete combustion of the fuel due to cold cylinder temps. Get the thing up to operating temps and see what it does.
Old Mar 14, 2006 | 03:28 PM
superman's Avatar
Under further inspection it looks like the injection pump was recently replaced (it's VERY clean).
Maybe the timing is off?
Old Mar 14, 2006 | 03:48 PM
Mechanos's Avatar
You won't be able to tell anything for sure until you get it up to operating temps.
Old Mar 14, 2006 | 05:41 PM
superman's Avatar
So much for tha idea. THe dealer who had it there would not even take a bid below $10K!! Truck wasn't worth near that especially with not knowing the actual mileage and the potential problem(s) it has.
JARHEAD
Nov 21, 2005 07:27 PM
2500Ram
16
Oct 17, 2005 03:43 PM
LDean
Feb 28, 2005 09:56 AM
bigbaddiesel
Jan 24, 2003 12:37 AM
