new project
Old Apr 26, 2011 | 06:46 PM
gunnie's Avatar
new project
Hi Guys
Bought a new to me '01 2500 4x4 5speed. this thing is really going to be a project and I need some help. I have a no buss in the odometer and none of the gauges work, I can turn my high beams on 8 or 10 times quickly and everything comes to life again but only briefly and the no buss doesn't ever leave the odometer while I'm doing this. Radio works, lights all work, A/C and heater work fine. I have scoured the past posts and searched everywhere but am still stumped. I tried all the electrical connectors I could find including the bolted connector in the fuse box, what I'm wondering is there a step by step elimination process I could go through? Any suggestions would be welcomed.
Thanks, gunnie
Old Apr 26, 2011 | 07:58 PM
nothingbutdarts's Avatar
My 01 did that to me and I found one of the two plugs plugged into the back of the insturment cluster had worked it's way out after I pulled the cluster out. They are kind of held in there cheaply.
You could look there.
Old Apr 26, 2011 | 08:23 PM
gunnie's Avatar
I pulled the instrument cluster out today thinking maybe that could be it, put di-electric grease on the connections and reinstalled but nothing changed.
Old Apr 26, 2011 | 10:03 PM
You might read through this:
https://www.dieseltruckresource.com/...s-t223809.html
Old Apr 30, 2011 | 09:37 PM
gunnie's Avatar
Can I take the pcm out of this '01 and put it in my '00 to verify if it's good or bad? will they interchange?
Thanks
TNH
Sep 4, 2011 11:42 PM
Johnelliott52
Oct 22, 2010 10:12 PM
Rammer64
Oct 17, 2004 11:31 PM
CruisingRam
Jun 3, 2004 09:36 PM
DieselDaze
Apr 7, 2003 01:43 PM
