New Injector Pump
Old Mar 12, 2003 | 04:44 PM
packfan25's Avatar
New Injector Pump
I have a 2001 ctd with 30,000 miles on it. I have had problems with lack of power (on occasion) since it was new. The dealer always told me they couldn't detect the same problems when ever I would take it to them so they wouldn't do anything. After reading some posts on this forum I just took it back this last week and told them I wanted them to check it out again. They did finally check some pressures after I requested it and just called me back to say they will be putting in a new injector pump. I asked about the lift pump and they didn't really tell me anything. Do I need to make sure they change the lift pump or can the lift pump be OK and the injector pump be bad? Is there anything else I should ask about when I pick up the pickup? I am really glad to have found this forum. If it wasn't for all of you I would still be driving around with a bad injector pump. Thanks alot.
Old Mar 12, 2003 | 05:37 PM
chuck3's Avatar
Re:New Injector Pump
Yes the lift pump could still be good but 99% of the time its the bad lift pump that takes out the injection pump. I would get a gauge and check the pressure after they are done.
Old Mar 14, 2003 | 12:40 PM
CTD2500's Avatar
I would seriously beg them to confirm the lift is OK and have them replace it if its not. Otherwise I would buy one from Cummins and ask that they install it for you. I couldn't imagine installing a new VP not fully knowing the lift is OK. Why have a new injector pump that starts out life being starved from the get go. If you have to, I'd pay myself just for peace of mind. Dont assume its fine because they "think" it is.
Old Mar 14, 2003 | 02:46 PM
packfan25's Avatar
Just got the pickup back today. When I asked if the lift pump was OK they said yes the checked it and it was OK. Then I asked what the pressure readings were and he didn't have an answer for me. He just changed the subject. He said the reason they replaced the injector pump was because the computer showed it was malfunctioning. I don't know what to think. I better just go get myself a gauge and install so I can see what is going on with the lift pump.
Old Mar 14, 2003 | 02:48 PM
HeberRam's Avatar
Pack....Make sure the lift pump is checked, and should be changed. I have never heard of an injection pump failure and not have a bad lift pump! ( however, anything is possible?). As Chuck3 mentioned, 99.9% of injection pump failures are a result of failed lift pumps! Depending how many miles you have on the truck, the next injection pump $1500-1800, plus $130, plus labor will be on YOU!.<br><br>Steve :'(<br><br>P.S. Install a mechanical fuel pressure gauage ASAP!
Old Mar 15, 2003 | 02:18 PM
Adam C's Avatar
Just took my 2001 with 31,000 miles in for similar symptoms. The lift pump was replaced under warranty,however, on the way home from the dealer the injection pump failed. As soon as they replace the injection pump I'll put in an aftermarket lift pump!
Old Mar 15, 2003 | 04:13 PM
BigBlue's Avatar
That sucks man. I hopefully caught mine soon enough. If not, then the injection pump is on me. :'(
Old Mar 17, 2003 | 11:06 PM
Haulin_in_Dixie's Avatar
Cummins told me this week that they can supply me an injector pump around $500 exchange. Of course not installed. Eased my fear somewhat.
Old Mar 18, 2003 | 03:09 AM
atoughram's Avatar
I must've ran around for 10,000 miles with a bad lift pump.... VP still going strong (looking for some wood to knock on..). Replacing an injector pump doesnt look that difficult.. Prolly easier than my old 6.2 chebbie..
Old Mar 18, 2003 | 07:11 AM
torquemech's Avatar
The injection pump can go bad ,with a good lift pump. I've replaced several were the lift pump press was 13-15 idle, 9-11 wot. In them cases the inside pressure rings were wore so the pump wasn't suppling press to injectors.
Old Mar 18, 2003 | 06:15 PM
phox_mulder's Avatar
I lost my VP44 at 4,000 miles on the odometer.<br><br>Lift pump was good as it could be.<br>Even checked myself with a Briarhopper after the fact (thanx Chuck3 ;D ).<br><br>Must have been bad from the get go.<br><br>2002 truck purchased March 1st 2002, built in Mexico.<br><br><br>Some have reported many many miles on the lift pump without failure, some many many miles before first failure.<br>Some are bad right from the start.<br><br>Same goes for Injection pump.<br><br>Luck of the draw I believe.<br><br><br>phox
gablekevin
Sep 19, 2006 12:12 AM
jbevly
Sep 5, 2006 03:59 PM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
