New FASS DDRP
Old Jun 10, 2010 | 11:59 PM
TankerIP's Avatar
New FASS DDRP
Today I got my new DDRP by FASS installed. I can't say it was a lot fun, but I sure am glad it's in. I purchased it from Thoroughbred Diesel and they had it here in a couple of days.
Removing the old Carter campaign pump was relatively easy. Putting the DDRP in was a little difficult because it is heavier and there really is only enough space to get one hand in there. So where you really would like to have 3 hands to hold and twist, I had to just let one hand try to do most of the work. Hardest task for me was to get the inlet banjo bolt started. I just laid the new pump on top of the starter, so that I could maneuver the hose with my left hand.
I put this pump in to solve an old problem I've had of the low pressure idiot light blinking. I was really worried that my lift pump was marginal and going out soon. https://www.dieseltruckresource.com/...t-t219399.html While the situation would improve if I put a new filter in, eventually the low pressure "blinks" would increase.
One thing - when I took the inlet hose banjo bolt off the old pump, it was not torqued to what I would like it to be. It was not loose, but it was easy to turn the wrench. I wonder if the old pump was sucking air and causing the low pressure dips?
Now everything is good. No blinks. I can feel the difference in the engine at cruise. With a four year warranty I should be good for a while.
Attached Thumbnails New FASS DDRP-img_1212.jpg   New FASS DDRP-img_1213.jpg   New FASS DDRP-img_1214.jpg   New FASS DDRP-img_1215.jpg
Old Jun 11, 2010 | 05:05 AM
rams2500's Avatar
I have been pleased with mine.
Old Jun 11, 2010 | 08:07 AM
nickg's Avatar
small tip, when working on LP remove two bolts holding filter canister, this allows you to move canister to the side to replace pump, and give lots of room to work
Old Jun 11, 2010 | 07:41 PM
southerman's Avatar
what pressure do you show at idle?
Old Jun 12, 2010 | 11:02 AM
Copenhagenjunkie's Avatar
Mount it on the frame in front of the fuel tank, its much easier.
Old Jun 12, 2010 | 03:47 PM
TankerIP's Avatar
I've seen many posts about frame mounting pumps. This seems tough for someone with my limited abilities to do. First I would have to find a way to mount it. I haven't seen any frame mounts that fit the DDRP/OEM pumps. Then I would have to figure out how to get that mount on to the frame. Wiring would have to be extended to the rear and secured (strapped) to the frame. Also, I would then have to splice the fuel line. The current fuel line won't stretch to the filter housing, so I guess I would have to buy a whole new line from back to front. All this, and then I would have to do it laying on the ground. I don't have a shop or lift. Is it really easier?
It might be an option, but someone needs to market the frame mount kit for the DDRP with simple to follow instructions.
On the other hand, that's why I bought the DDRP because it is form fit for the stock pump. If I thought it would be easy to tackle the frame mount, I might have considered airdog or one of the other options out there.
Old Jun 12, 2010 | 03:50 PM
TankerIP's Avatar
I don't have a pressure gauge - just the idiot light. Since before I had some "blinks" in the light and none now, I know I have above the minimum pressure.
Old Jun 12, 2010 | 04:46 PM
southerman's Avatar
oh ok then was just going to suggest to mount on frame i get 18 psi at idle
Old Jun 12, 2010 | 04:51 PM
http://www.glacierdieselpower.com/pr..._id=RP-100-D24
This is very similar if not just like ddrp with fass sticker, buy an lp relocation and big line kit. The lp relocation kit comes with wiring but you would need to get a $4 relay.
Not harping on you, just letting you know that there are kits available and it's much easier to work on your back with ample space on the frame than the crowded engine compartment.
FWIW,You should probably also trigger the ddrp from a relay and not directly from stock wiring. I'm not familar with the ddrp wiring.
HTH.
ovis
May 22, 2009 12:21 AM
mrock
Jan 5, 2009 09:10 PM
leeboy
Dec 12, 2008 08:35 AM
Desperado
15
Dec 9, 2008 10:59 AM
dodge_24
Oct 18, 2008 05:43 AM
