Late Lift Pump Change
Old Aug 24, 2006 | 01:48 PM
chasd60's Avatar
Hopefully not too late.....
My truck has been acting fuel starved at high rpm's so I figured it was at least due for a filter change. After I changed the filter, I bumped the key and no hum, just relays clicking. I tried several times and even put my hand on the lift pump and there was nothing at all.
I did have this code too.
P0230 Transfer Pump (Lift Pump) Circuit Out of Range
I changed the lift pump and everything seems fine, no high rpm starvation any more. Lift pump change from the top was simple, probably 35-45 minutes.
I hope there isn't any significant damage to my IP.
I guess guages are next, probably the Quadzilla Commander.
Old Aug 24, 2006 | 02:09 PM
mgstroker95's Avatar
gauges are a must! I hope you didn't injure your VP!
Old Aug 25, 2006 | 09:13 AM
Mopar1973man's Avatar
You need a set of these... QUICK!
If I would of listen to these guys a long time ago I could of saved my the trouble of going t othe dealer twice for LP pump and waiting a week and returning back to change the dieing VP44... So Give her time the VP44 is going to head south...
Old Aug 26, 2006 | 11:47 AM
chasd60's Avatar
Hopefully it will be quite a bit of time. I only put about 4k miles on the truck per year.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
CTD2500
Mar 25, 2003 02:35 PM
soundbrz
14
Nov 20, 2002 03:35 PM
