Installed Fuel Pressure Gauge
Well I installed a fuel pressure gauge today. Seemed pretty easy. So i start the truck up after i get the line to the sender bled and its reading 2-3 psi at idle and drops to 0 when revved up. So i guess i need a new LP, could use some suggestions on a not too expensive/hard to install LP. I don't wanna kill my VP!!!
Same problem as me. Install monitoring device...find defective LP. I've go another post going now about mine.
I looked at lots of different options today. If you want a stock replacment, I found that most shops in my area are using a Delphi pump. One recommended the Alliant pump. They've only been using it for two months, but no issues so far. It has a fail safe bypass built in. I'm sorry I don't have an online supplier or link. I'm getting mine locally. I had a page eariler but cannot find it again. Cost should be $150-200.
Nathan
Nathan
You are going to read a lot of ideas on what is the best. I installed a Holley Blue and totally bypassed the in tank pump and am having no problems at all. That would be a cheap/easy fix in my opinion.
I think NAPA may have the Carter OEM with lifetime warranty for about $125, more or less .
The Vulcah kit is highly recommended upgrade! Improved flow to VP44, eliminates Banjo bolts.
WEll i didn't think about checkin NAPA but i found 'em on e-bay for about that price so that should be here by friday, maybe i'll get it installed sometime before/during this weekend just going to go back with a stock type for $$$ right now maybe upgrade later
Your NAPA is cheaper than mine. They wanted $210 for the Carter pump (sold under the NAPA Fuel Pumps name).
Picked up my Alliant pump last night. Reading through the papers, it says I will see lower pressures, but flow will be better. Hmm..... didn't know that, guess we'll see what the guage says after install.
Nathan
Nathan
You could do a FASS HPFP with 3/8" or 1/2" line, a Draw Straw, and a 1/2" line from the filter to the injection pump. This way you would eliminate all restrictions in the fuel system and have peace of mind that it is solid.
Man.... wish i had known that yesterday, thats cheaper than the one i bought off e-bay.. oh well, it was on my doorstep when i got home so i already got it installed 12-13 psi at idle and drops to 5-6 at WOT now
dodgeguy71
17
01-19-2012 12:52 AM
Spooler
02-12-2006 11:43 AM
NeedMoPower
09-07-2005 08:43 PM
Lrdchaos
07-12-2005 06:20 PM
JCHMOTOR
15
06-22-2004 08:25 PM
