how to tell
Old Jan 31, 2010 | 11:01 PM
silotree's Avatar
how to tell
how can i tell if i have a 53 block
Old Jan 31, 2010 | 11:18 PM
matthais's Avatar
crawl under the front, left side, and look up at the block on the front, directly under the injector pump (by the PS pump). You should see a large wiring harness mounted to the block. Directly below this, just above where the oil pan meets the block you will look for a "53" cast in the block. The numbers will be about 1 inch tall. Here is some more info
http://stamey.info/Truck/Cummins53BlockFAQ.htm
Old Feb 1, 2010 | 08:45 AM
RowJ's Avatar
Rare on 01's. Only earlier built 01's had them, I believe.
Got rear disk brakes (making it actually an 01.5), than not a 53 block, AFAIK?
Good Luck!
RJ
Old Feb 1, 2010 | 10:09 PM
silotree's Avatar
yes mine has rear disk breaks. thanks for the help i am goin to crawl under it tommarow and look for the 53 cast
Old Feb 1, 2010 | 10:12 PM
1dumrednek's Avatar
so none of the 02's have 53 blocks?
Old Feb 2, 2010 | 07:58 AM
RowJ's Avatar
Correct! All 02's (and most 01's) have the excellent, heavy, Mexican block made in Alto Largo, by "Teksid".
Smaller # stamped on the block and more of them..... and hard to read.
These Mexican blocks are the strongest cast, ISB blocks ever Mfg.
Suggest changing signature to 01.5! Everyone will know what that means (except your Dodge dealer ).
RJ
Old Feb 2, 2010 | 09:52 AM
matthais's Avatar
should be a 57 block high nickle
Old Feb 2, 2010 | 08:43 PM
silotree's Avatar
thanks for the help rj
Tackdriver
Jan 22, 2003 07:45 AM
bigbaddiesel
Jan 5, 2003 10:09 AM
OH Sick
Dec 10, 2002 04:32 PM
Commatoze
Oct 11, 2002 11:03 AM
