high egts
Old Apr 12, 2006 | 10:36 PM
bstitt's Avatar
Angry high egts
my trucks egts have been running higher that normal. normaly it runs 500 to 650 post turbo maybe 750 getting up to speed on the highway, 600 to 650 at 70mph up small grade. now it will grt up to 900 just driving around town like a sane person. i was watching them today while i was gettin on it comp box on 3 on 2 and it was up to 1250 in about 15sec. it still builds 37 pounds of boost but it seams like theres alittle more turbo lag then normal too.
any ideas?
i looked around and didnt see any boots blown off partially. i hoop is not my turbo taking a Sh**.
Old Apr 13, 2006 | 11:07 AM
high country's Avatar
well I was gonna say a boost boot but your numbers are good and it sounds like you checked that. I would look at the air filter & intercooler, are either plugged? I hope so cause the only other thing that I can think of would be in the vp44 not giving you timing advance......you don't want that.
Old Apr 13, 2006 | 02:25 PM
Gene007's Avatar
High country
My truck is doing about the same thing. It will boost to +35psi, but will come down to almost nothing. Maybe 3 psi at 60 mph. (was 7-10 psi before) No leaks. The timing advance from the VP44, is that electronics? Or could it be the gear has slipped on the VP44?
Bstitt
I will be going through mine next week, if I come across a fix I'll let you know. Our problems seem to be same
Regards
Gene
Old Apr 13, 2006 | 04:26 PM
newriverSpecon's Avatar
Have you looked around the exhaust manifold? If you have no leaks on the cool side it might be on the cold side. If you looseing drive energy (not necesarily drive pressure) you could get that.
Randy
Old Apr 13, 2006 | 11:21 PM
007 if your boost falls off once you get to constan speed, that is normal, think of the turbo as load sensing as load falls so does boost,
newriver, I kinda thought along those lines also but the fact that he is getting so much boost kinda pulls me away.....maybe
Old Apr 13, 2006 | 11:41 PM
Gene007's Avatar
High country,
I understand where your coming from, but my pressures used to stay constant above 7psi while traveling 60-65 mph. Now it drops down significantly
Regards,
Gene
Old Apr 14, 2006 | 01:23 AM
Originally Posted by Gene007
High country,
Regards,
Gene
what do the egt's show? did they go up?
Old Apr 14, 2006 | 01:54 AM
Gene007's Avatar
High country,
Yes the EGTs do go up, just like bstitt's temperatures. They go up quick and high if you get on it a little
Regards,
Gene
Old Apr 14, 2006 | 01:49 PM
007did your temps used to be lower at that boost level? I am curious if you might be just a bit over what the hy can keep cool, they like a bit less pressure. other things might be, plugged inter cooler from the puke bottle, a plugged air filter, and lack of timing.
Old Apr 14, 2006 | 09:07 PM
Yukon Dodge's Avatar
When I replaced my resonator and muff with a straight pipe, it lowered my EGT's significantly. In fact, with the fiver on, I can't get it out of the green under any conditions. If you have a partially plugged exhaust system, it seems you are going to have higher EGT's, along with normal boost values.
Old Apr 16, 2006 | 09:51 PM
bstitt's Avatar
i dont know i didnt pop off test this jammer tips. i got a set of stock injectors on the way to put in well i get them tested. but this temp problem didnt start right after i put them in.
how can i tell if my intercool is cloged?
can i clean it out somehow?
thanks of the suggestions.
Old Apr 17, 2006 | 12:46 AM
You got me there, but if you don't get any responses on this thread, you might re-post it specifically asking about clogged intercoolers...you also might do a search on the forum. Could be someone else has had something similar happen.
Old Apr 17, 2006 | 09:50 AM
the intercoolers clog from the breather bottle spewing oil onto them. you only need to look through it, shine a light from the inside and you'll see what I mean. I used carb cleaner on mine, a pressure washer will flatten the cooling fins so don't use anything really high pressure, garden hose would be ok. I don't know how much drop you are going to see if you clean the cooler, not the 500* you are seeing, but it could be a contributing factor.
lgp9999
Sep 8, 2007 11:19 PM
Bradleysram
32
Nov 25, 2004 09:25 AM
BCarmicle
Sep 22, 2004 12:10 PM
Towrig
18
Jul 16, 2004 02:34 PM
NOTSTK
Aug 9, 2003 09:10 AM
