Help! Lift pump and Injector pump!!!!!
Old Jan 17, 2007 | 10:01 PM
rtmick's Avatar
I was driving my 01 dodge 2500 4x4 and it lost all power, it regaind power after a few seconds. the engine light came on. I took it to the dealership the next day, they said I had a transfer pump and a injector pump bad. This will cost $3,370 +tax. Is the dealership trying to get more out of me? Do you think I can get by with just replacing the lift pump? There was no other sign of failure. The truck was running great. Someone please help!!!!!
2001 Dodge Ram 2500 Cummins HO, 4x4, stock
Old Jan 17, 2007 | 10:07 PM
mbfarms's Avatar
Turn your switch off and on three times. Read the codes from the Odometer. Injection pumps normally run around $1100 plus $400 core and you can get a FASS or Walbro setup from $300 to $650. Labor on the injection pump will be somewhere around 3 hours and the pump kits will take about 3 hours. Far cry from $3370.
Old Jan 17, 2007 | 10:23 PM
Stormin_Norman's Avatar
I would agree, most diesel shops will charge half of what the dealer wants.
Old Jan 17, 2007 | 10:45 PM
Tate's Avatar
Read this, https://www.dieseltruckresource.com/...=year+warranty, then read your warranty book. You may be able to get it covered under warranty. If you can't, go find a shop todo your work. Dealers rip you off left, right and center.
Old Jan 18, 2007 | 10:44 AM
zulusafari's Avatar
Interesting reading. Too bad my truck has over 200k on it and the VP is throwing the p0216. My lift pump went out about 30k ago, but that is still too late.
Old Jan 19, 2007 | 07:02 AM
J BODY's Avatar
Last time I checked the DC reman VP for the 01 etc was around $1800. Lift pump conversion package to tank unit would run around $700+ to install......and add labor for the VP install and diagnosis.
.....I quote a rate using DC parts, but also have an aftermarket source that we use that can put the diag, VP, and original style lift pump + filter at a little under 2k. Not as cheap as doing it yourself, but close to a $1000 less than what it could have run and I find it comparable to what other shops charge for the job in our area. Even cheaper in some cases. Shop around if you can find another shop you are comfortable with.
gablekevin
Sep 19, 2006 12:12 AM
jbevly
Sep 5, 2006 03:59 PM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
