Fried ECM?? Dealer said first he has seen. Is this common?
Old Dec 22, 2009 | 01:46 PM
zachv's Avatar
Truck: 2002 CTD HO, 6-speed, 4x4, with an Edge EZ and Air Dog.
Yesterday, while driving my son to school my truck started bucking and then would do nothing other than idle--would not build power. Towed to dealer and they say the ECM is fried, likely by a broken alternator that was over-charging. The mechanic working on the truck, who is a friend, said it is the first bad ECM he has seen on a CTD. I am looking at a new ECM and alternator.
My question is if this is common and could the EZ module have anything to do with it? I searched the forums and did not see anything regarding this.
Thanks for your help.
Old Dec 22, 2009 | 04:02 PM
patdaly's Avatar
Edge could certainly do it, take it out first.
I would think you are describing more the VP44 electronics rather than the ECM.
Old Dec 22, 2009 | 06:42 PM
SIXSLUG's Avatar
My ECM went T U in MT August 08. Engine light came on and sputtered to a stop. It started up and ran for about 1/2 mile and quit for good. Towed back to Kalispell and it started and ran but had no power. Diagnosis= ECM failed.
One other thing, when I started it that morning it missed twice. It had never done that before. The codes were all ECM related and a lp code was in there also. That got replaced after 1 month.
Kurt
Old Dec 22, 2009 | 06:56 PM
zachv's Avatar
Kurt
You had to replace your VP44 shortly after the ECM? Boy, I do not look forward to that...
Old Dec 22, 2009 | 07:52 PM
bostiguy's Avatar
I believe he said his LP (lift pump) went out, so not nearly as bad...still not good either though.
Old Dec 23, 2009 | 07:40 AM
zachv's Avatar
Duh, can you tell I am worried about forking out $1500 for a VP44? Sorry about that.
I am going to call Edge today to see if they think the EZ module could have done any of this. In the meantime, can anyone explain how the EZ module could wipe out an ECM? I forget the terminology, but I did not "tap" any wires, the EZ module just plugs in between some wire harness on the driver's side.
Old Dec 23, 2009 | 08:23 AM
patdaly's Avatar
Dunno if the edge takes out the ECM, but I have seen several guys here who had no starts, simply remove the edge and the problem went away.
Before I put an ECM in I would at least remove the edge and try to start her.
Old Dec 23, 2009 | 09:40 AM
Junk Man's Avatar
You are talking about some expensive parts. I'd want to understand what test results and logic indicate the need. Also would want a guarantee that those are correct - ie: no fixie, no pay. Many shops want to be paid for part installation even if it doesn't correct problem. You can install the wrong parts yourself. A shop should be held to a higher standard.
Old Dec 24, 2009 | 12:00 PM
SIXSLUG's Avatar
My ECM cost $750. They overnighted it from Chicago. It only took four days to get to Kalispell and about 1/2 hour to install it.
I'm not usre what killed the Lift Pump, but the dealer in town here in WA thought it could be realated to the ecm failure. My Alternator checked out fine, even thouhg one of the codes was overvoltage. "voltage too high to ECM" or something like that.
Kurt
HevMetl
0
Nov 11, 2009 08:01 PM
the496rocket
Nov 1, 2008 01:11 PM
Fronty Owner
Apr 21, 2008 09:43 PM
egpeil
Oct 4, 2007 05:48 PM
