Filter drain leaking
Old Jan 4, 2014 | 09:58 AM
Crallscars's Avatar
I started my truck yesterday morning, temperature dropped to 9 degrees, to find I forgot to put fuel additive in the tank. Engine wouldn't pull or go over 1700RPM. New filter and fuel additive fixed both.
My fuel filter valve and the drain are/were both leaking fuel, I temporarily put a hose with a bolt in one end on the drain and disassembled the valve handle to stop the leak.
Are they repairable or do I have to buy the bleed valve assembly?
Old Jan 4, 2014 | 10:44 AM
carl48's Avatar
I just got through fixing one about a week ago. we took the filter housing off and removed the drain, you need to replace three o rings. two are on the housing to drain and one on the lever arm. my sae o rings did not fit, they are metric. I did not look at the size but you need to get a kit anyway. took about 5 minutes to fix and 10 minutes to air test to 25 psi
Old Jan 4, 2014 | 04:41 PM
98whitelightnin's Avatar
http://www.genosgarage.com/FLEETGUAR.../#.UsiN8owo45s
Old Jan 4, 2014 | 05:13 PM
Crallscars's Avatar
Thanks for the tips, on the kit,
I see 2 small "O" rings and a large one,whats the large one for?
Glad to see I am not alone with a leaky pump.
Old Jan 4, 2014 | 05:31 PM
carl48's Avatar
the large one is to replace the filter o ring, when you take the filter cap off the cap tends to stretch the old one.
Old Jan 9, 2014 | 07:33 PM
Crallscars's Avatar
Originally Posted by 98whitelightnin
Thanks for the help all, I contacted Geno's and got the parts quickly.
Now I have to replace the brake pads on all 4 wheels
jesussaves
May 10, 2013 04:30 PM
klx650a2
Jan 10, 2008 12:08 AM
Journier
Nov 25, 2005 08:41 PM
wrk24wheel
Oct 18, 2004 12:26 PM
wooff
May 1, 2003 11:22 AM
