Engine runs then looses fuel.
1999 Dodge 3500 4x4 5.9
The truck has a hard start issue where the truck would take a while to start and would run for about 30 seconds and then the fuel cuts out. After it stalls out it takes a while to get back in the filter housing. After it does eventually get fuel to the filter it will repeat the whole process with no codes even while the truck is running. The truck does have a raptor lift pump in it as well. Any ideas on what could be causing this? All input is appreciated.
Well that should be pretty easy to check as most electric pumps make a decent hum when they run.
You could also check it out with a fuel pressure gauge after the lift pump, which is something I put on most any 24V I own. This is because the lift pumps die, then take out the injection pump in short order.
snowmanx
May 31, 2019 03:37 PM
sundance32us
24
Dec 13, 2015 07:36 AM
reasonspj
15
Jan 15, 2010 04:08 PM
bglz42
31
Apr 7, 2007 07:34 PM
wood_n_soldier
Jul 19, 2004 03:01 PM
