what the .... ? Start up issue.
Old Jul 19, 2004 | 01:13 PM
wood_n_soldier's Avatar
For the past few weeks I have been noticing a slight dry cough sound when I restart my truck. It generally occurs when the engine is completely warm, then shutdown and restarted within a few minutes. Today however I ran the engine about 10-15 minutes and then turned it off for about 30 minutes… when I restarted, the engine cranked like there was no fuel, I turned the key back and tried again and it started. I replaced my fuel filter Saturday (it was just time).
What’s going on?
Old Jul 19, 2004 | 01:46 PM
Commatoze's Avatar
Possible fuel delivery problem? Need to check to see if the lift pump (transfer pump) is working. Did you drain the filter cannister when you changed the element?
Old Jul 19, 2004 | 01:55 PM
MOUSE's Avatar
check fuel pressure, and pull codes, go from there could be lift pump and VP-44 related
Old Jul 19, 2004 | 03:01 PM
Yes I did drain the filter canister - Why? How do I check my lift pump?
dan123dbl
Feb 13, 2015 05:47 PM
cgoaks77
Dec 9, 2010 09:06 AM
CoolumConst
Oct 11, 2008 10:00 PM
DDysput
May 5, 2004 07:44 AM
