Engine Idle while warming up
Old Jan 5, 2005 | 09:52 PM
  #31
KATOOM's Avatar
Originally posted by phox_mulder
The stock high idle function is dependent on too many conditions being met.
1. Intake Manifold Temperature less than 0°C (32°F) and,
2. Coolant Temp is less than 60°C (140°F) and,
3. The Transmission is in Neutral or Park and,
4. The Service Brake pedal is not depressed and,
5. Throttle = 0% and,
6. Vehicle Speed = 0 mph
Aftermarket high idlers can be turned on whenever and wherever usually.
phox
You mean you cant use it unless its colder than *32 out? Whats the good in that? I realize that I'm digging up old thoughts here but I clearly remember guys trying to fingure out how to find a way to get the ECM to high idle anytime buy using the PTO wiring. Has anyone ever got that to work?
Old Jan 5, 2005 | 10:14 PM
  #32
Bradtothebone's Avatar
1200 isn't enough.. (Not that I'm anyone to talk, my truck piled up cause I was neglegent) but last year, I put it at 1450 to 1500 or so, heater on middle and low fan, mind you it was coooooolld -40 or so... When sitting at the lights I put the park brake on and the 3cyl idle would kick in immedialty,,,,
BRad
Old Jan 5, 2005 | 10:34 PM
  #33
Dr. Evil's Avatar
My high idle switch is set to around 1400....for warmup I use the e-brake instead.....
Old Jan 9, 2005 | 11:33 AM
  #34
Rick/Illinois's Avatar
Originally posted by dieselnewbie
I always use high idle, either the cruise control buttons if it's over freezeing but under 50, or I just let the auto-high idle kick in if it's cold enuf to activate and I always allow it to fully warm up, or I drive off before hand.
I think I just learned something today.........I didn't know that I could use my cruise control to set a high idle like we can do with our 4300 Internationals. I'm going to have to try that. I knew the auto idle would jump up if the temp was cold enough.
My powersmoke would only kick in fast idle when the temp was below 30 degrees or so.
Thanks for the info.
Old Jan 9, 2005 | 03:54 PM
  #35
dieselnewbie's Avatar
The idle control via cruise control doesn't work out of the box.
You have to have a dealer enable it by changeing the software in the truck, which is a quick routine operation for most of them.
Read this TSB link, print it out and bring it to the dealer. It took my dealer about 10 minutes to enable it in my truck.
Here it is:
http://www.dodgeram.info/tsb/2004/18-004-04.htm
It's definitaly worth it, it's a great feature.
Old Jan 11, 2005 | 08:50 PM
  #36
damnyankee's Avatar
OK, I took mine in for routine service, oil change , tire rotation etc... gave them the printed of TSB for the high idle.
When I picked it up they said they didn't do it because the Core temp was 125 or greater therefore not warranting the update.
I didn't ***** much for 2 reasons:
1. I was in a hurry and didn't have time
2. I didn't read the TSB real close prior to taking it in, all I knew was I needed the update.
Now I have read it close and it indicates the update is my (the customer's ) decision to have it done. Before I go make a fool of myself am I correct or not?
Thanks in advance.
damnyankee
Old Jan 11, 2005 | 09:01 PM
  #37
Not sure.
They did mine with no questions asked because my truck was only 4 months old and they probably didn't want to upset a new customer.
You can complain about one or more of the symptoms on the TSB, even if the complaint may not be legit, and they should do it no problem.
If they still don't want to do it tell them you know it's a quick operation and you'd be pi$$ed off if they don't, and if they still refuse, take it to a different dealer.
That's what I'd do anyway.
Old Jan 13, 2005 | 08:05 PM
  #38
johnh's Avatar
warm up
in 0 to 11 degrees temp it will not warm up at an idle (experiance talking)
Old Jan 15, 2005 | 07:46 PM
  #39
upersleder's Avatar
my 02 does not have the cold idle enabled. i have been going with the stick in the seat method, but one problem with BOTH of these...... I CANT USE THEM WITH MY REMOTE START!!!
for some reason when i use my remote starter with the stick it just shuts the truck down. why is that? either way it seems i have to get cold
Old Jan 15, 2005 | 08:26 PM
  #40
phox_mulder's Avatar
If the brains of the remote starter sees go pedal being pushed it thinks someone is trying to steal the truck so it shuts down.
Just got my high idle enabled (finally) and it works with the remote starter, as the go pedal isn't moving, just the idle speed is.
phox
Old Jan 27, 2005 | 02:31 PM
  #41
anpconnors's Avatar
I have had the TSB done on my 00BR and it works GREAT! 2 degrees today and truck was warm after 20min of 3cylinder idling. It is a challenge to get used to the increased noise level. Only one trip to the dealer, with the help of this site and a printout of the TSB for the writer and the tech. Paid 1 hour of time, well worth it. Thanks!
Kurran
Jan 23, 2013 07:58 PM
GrizzyZr2
Oct 26, 2007 03:13 PM
Charlie8301
15
Sep 29, 2004 04:32 PM
AaronT
Apr 8, 2003 06:22 PM
