engine heater
Old Jan 24, 2005 | 06:27 PM
jj3500's Avatar
engine heater
cold up here in the east....how long is it safe or suggested to keep the block heater on for. several hours...days?
Old Jan 24, 2005 | 06:47 PM
phox_mulder's Avatar
Several hours should be enough.
It is safe to leave plugged in all the time though, just hurts your elec. bill a little.
phox
Old Jan 24, 2005 | 07:00 PM
dodgediesel4x4's Avatar
Many members have their trucks plugged in to a timer, and set it 3 hrs before they need to leave. Keeps the elc. bill down, some, and leaves plenty of time for the grid heaters to do their job.
Old Jan 24, 2005 | 07:04 PM
Mechanos's Avatar
Grid heaters??? Plugging the block heater in has nothing to do with grid heaters.... except that is causes the grid heaters to cycle off in only a couple seconds when you turn the key on.
Old Jan 24, 2005 | 08:30 PM
jrs_dodge_diesel's Avatar
For those of you worried about the electric bill :
Originally posted by brohloff
Easy to calculate the cost to run the heater.
Look on your elec bill and find the cost per kilowatt hour.
Our last bill was 6.6 cents/kilowatt (1000 watts) hour.
Lets assume the heater is a 1000 watt heater. (I've heard some say 750, some say 1000, some say 1500 watt - So 1000 is a good average number).
A 1000 watt heater, run for 1 hr would cost 6.6 cents. Therefore leaving it plugged in all night (say 9pm to 7 am) is 10 hrs is 6.6 x 10 = 66 cents added to your electric bill!
Buy a timer, do 4 hrs, cost = 26 cents, save 40 cents off the 66 cents and pay for an $8 timer in 20 nights............Peanuts compared to a $35K Truck !!!
PS: If truth be told the few cents spent heating the truck engine is probably more than made up in fuel saved warming a cold diesel engine (Cold engines eat far more fuel than a warm engine - not to calc in the quicker confort factor).
Bottom line - Running a heater is FREE (No kidding)!
Brohloff/retired engineer(can't you tell?)
BTW our heaters are 750 watts by using Ohm's law.
Here's another tip that is out of the ordinary. Plug your block heater in at the end of the day when you are done with the truck. Here is the thinking behind it. Its easier to keep something warm that is already warm, that to take something cold and make it warm. Just an idea.
Old Jan 25, 2005 | 10:32 AM
infidel's Avatar
You're right it is easier but it makes no difference in power use since our block heaters don't have a thermostat, when plugged in they are always on using the same amount of juice.
Old Jan 26, 2005 | 08:54 PM
Right, power use is increased (plugged in longer) but engine temps might stay up better to.
Old Jan 26, 2005 | 10:42 PM
tool's Avatar
Nope.
If your producing X number of BTU's at any given time the temp will ultimately be the same.
Old Jan 26, 2005 | 10:59 PM
tshikle's Avatar
Hey guys I'm confused. Is there both a block heater and a grid heater in our trucks? I thought, probably wrong, that there was only grid heaters. What would happen if you left your truck plugged in and fired up the engine? Would something overload and short out?
Old Jan 26, 2005 | 11:09 PM
No.
Grid heaters get their DC power from the battery,
block heater gets it's AC power from a 110v receptacle on your house or garage.
In fact, Cummins recommends leaving the block heat plugged in for a short while when starting in extreme cold.
phox
NoSmokeNoGo's Avatar
The block heater has nothing to do with the grid heaters. The grid only turns on when you turn the key.
Old Jan 27, 2005 | 07:25 AM
Geico266's Avatar
Works great with a remote starter! I fire the truck up for about 5 mins while she is still plugged in, and I'm still drinking coffee at the kitchen table! That is livin man!
Old Jan 27, 2005 | 09:10 AM
RowJ's Avatar
Geico266 - That's sounds even better than being in an attached, semi warm, garage! I have to open the garage door to start my truck.
"T" - Two different functions. Grid Heaters heat cold air going into the engine when it's first started (replacing need for glow plugs)....Block heater pre- heats the coolant in the block!
RJ
Old Jan 27, 2005 | 03:29 PM
tshikle's Avatar
Thanks Guys. My brain was ozzing out of my ears on that. Glad you got me straight.
rjm022
Dec 11, 2019 09:17 PM
Ramrod90
Feb 3, 2009 07:39 AM
modiesel
Mar 7, 2008 10:44 AM
taildragger
Dec 4, 2006 10:00 AM
Reelay
Dec 1, 2005 06:14 PM
