Engine Block Heater Not Working
Old Nov 26, 2008 | 07:59 AM
scook6's Avatar
I went out this morning to start my truck, which was plugged in and I noticed that my wait light stayed on much longer than normal. So I checked under the hood and the valve cover was cold as ice. My question is this.... Does the power cord go straight to the heater? Or is there a fuse somewhere? If not the heater must have bit the dust. If so anything special that I need to know to change it? And where is the cheapest place to buy one? I have owned the truck since new so I know it is the original heater. Thanks
2002 2500 4X4 Q/C S/B Atlantic Blue
Old Nov 26, 2008 | 11:16 AM
nitrousn's Avatar
Cord goes direct to the heater no fuse. Most likely the cord is bad at the plug. Go to the hardware store and buy a HD universal replacement end. You can cut the end off and ohm between the two wires. If there is no resistance the reat of the cord and element should be ok.
Old Nov 26, 2008 | 12:46 PM
PaulDaisy's Avatar
I had this problem and it was the cord that chafed across below the radiator. A bit of solder, heat shrink and electrical tape fixed it up.
oilcan64
Nov 5, 2010 10:00 PM
Need95-00CTD
Jan 13, 2007 09:16 AM
Black Beast76
Dec 18, 2006 02:39 PM
mgfredrickson3
Feb 19, 2006 12:21 PM
dieseldon
Dec 9, 2005 09:53 PM
