Block Heater not working
Old Dec 12, 2006 | 09:49 PM
Black Beast76's Avatar
I pluged my heater in the other night and when I got up that morning to leave nothing had happened. Any Suggestions.
Old Dec 12, 2006 | 10:07 PM
phox_mulder's Avatar
Define nothing?
Only thing you'd notice is the "wait to start light" not staying on as long as if you didn't plug in.
Maybe a little faster crank over speed, and it will get up to operating temperature slightly faster with plugging in.
phox
Old Dec 14, 2006 | 12:35 PM
The wait to start light stayed on like i didn't even plug it up, and it took just as long to get to operating temp. as if I didn't plug it up.
Old Dec 14, 2006 | 12:40 PM
nitrousn's Avatar
Most likely the cord is bad right at the plug. You can replace just the plug end from one from a hardware store...
Old Dec 16, 2006 | 02:21 PM
Alright, thanks nitrousn.
Old Dec 16, 2006 | 03:03 PM
johnh's Avatar
put your hand on the engine, you should feel heat if it's working
Old Dec 16, 2006 | 03:40 PM
Geico266's Avatar
Cords seems to last only about 7 years. Depending on how many times you drive off with it still plugged in.
Old Dec 16, 2006 | 06:59 PM
1-2-3's Avatar
Just a plain ole guy
They make a sound like an old coffee perculator. Does yours do this?
Old Dec 16, 2006 | 07:55 PM
Geico266's Avatar
Check your coolant level, could be low. Mines makes no sound.
Old Dec 18, 2006 | 02:39 PM
Moose10's Avatar
That;s what mine sounds like too. Radiator is full, and overflow is up to full mark. It's made that sound since new, but only for about the first 10-20 minutes from cold.
You can even just grab the upper radiator hose....it should feel warm after a couple hours depending on outside air temp....after overnight, definitly should be warm.
Do you have power to the outlet you're plugging in at? Had to ask...
oilcan64
Nov 5, 2010 10:00 PM
scook6
Nov 26, 2008 12:46 PM
Need95-00CTD
Jan 13, 2007 09:16 AM
mgfredrickson3
Feb 19, 2006 12:21 PM
dieseldon
Dec 9, 2005 09:53 PM
