Block Heater not working
Old Feb 18, 2006 | 09:58 PM
mgfredrickson3's Avatar
My block heater quick working on my 01 Cummins. What can I do to test or just diagnose the problem?
Old Feb 18, 2006 | 10:02 PM
torquefan's Avatar
Using an ohmmeter, check for continuity between the 2 prongs on the plug. There should be approx. 19 ohms resistance. While measuring, wiggle the cord right at the plug and monitor for change. That's where most wire breakage occurs. If you see no continuity, remove the cord from the block heater, and test between the pins at the block heater. Also check for signs of heat and melting right at the block heater pins.
Old Feb 19, 2006 | 11:22 AM
neveragain's Avatar
Block heaters
For figuring out.
W = Watts
V = Volts
A = Amps
R = Resistance
W = V x A V = A x R
This is for basic electricity only.
You can take the meter leeds and put them on one end of the plug and find the other end female end the wide opening is the neutral and the male end has silver for neutral. If one end is bad cut it off and get another end and put it on for a ex cord.
Old Feb 19, 2006 | 12:21 PM
John Faughn's Avatar
If you get an open circut reading , check right at the plug end , I've found far more broken wires at this spot than bad heaters , the plug flops around and breaking the wires inside the insulation so it still hangs there but no conection.
oilcan64
Nov 5, 2010 10:00 PM
scook6
Nov 26, 2008 12:46 PM
Need95-00CTD
Jan 13, 2007 09:16 AM
Black Beast76
Dec 18, 2006 02:39 PM
dieseldon
Dec 9, 2005 09:53 PM
