Electric Fuel Pressure guage (HELP)
OK,
I'm gonna do it... I've put it off way too long... but I don't understand something.... WHY do sending units HAVE to be mounted verticaly?
can it be mounted in a more vertical than horizontal.... or does it need to be mounted pretty much vertical?
Geno's suggests an 18" greasegun whip to allow the sending unit to be mounted in a vertical plane.... Where are you guys mounting the sending unit that its NOT on the VP44 BUT still semi-vertical, and within 18 inches???
Thanks,
-Tim
Thanks,
-Tim
I've got a sender for the Quadzilla Commander and it's originally mounted on the VP44 schraeder valve hole which is about a 45 degree angle down. I have it mounted off the lower end of the fuel filter now and can't seem to get a good reading from it. It jumps around like it doesn't have a good ground or something even though I have checked and rechecked the ground (and added an additional ground strap). The Quadzilla manual doesn't say anything about the sender being vertical, but maybe that's my problem. What type of sender are you running, what's the model?...
-Tim
i think that it has to do with the rattling and plusing of the IP...the needle valve smooths this out and allows the sending unit to give an accurate reading....and NOW that i know that if this one DOES go bad i have a BRAND NEW ONE in the garage....so i just take the old one off the needle valve and swap it out....
NCA
I been thinking of buying one as well, which one did you buy?
I was going to buy the Fuel Filter cap from Genos and put the sending unit in the top also, but not sure which gauge to go with and what pressure range?
i do not think the cap measures the filtered fuel i have always used the taped banjo bolt on the bottom of the filter or on the pump i use a 18" grease gun hose and make my own snubber but you can run a search and several places have them i mounted the quad fuel sensor on the cp3 direct to the banjo bolt just like the instructions showed and then i started reading all of the failures in the electric units and the next day i added the hose and snubber just like i would do the mechanical the pulsing of two pumps and motor vibration has got to be a killer on them
As far as point of attachment.... I don't know about geno's fuel filter cap either, but I do know that if you check pressure at the VP44.... your getting a reading as close to the component most likely to fail as possible.... which again to me is a good thing.
I might change my mind on the 0-15psi guage and go up to the 30psi guage after more comments though...
OH YEAH.... 30 PSI it will be...where was my brain when I needed it?
-Tim
Last edited by imbodie; 04-17-2008 at 07:38 AM. Reason: Proof that knowledge is power and 30 psi is perfect
I just installed an autometer digital fuel pressure gauge 0-30 psi, and it works great, I mounted mine about 6 inches before the vp on a mr. gasket barbed fitting with the tapped hole, and it works fine. Also it is mounted on an angle, and i get a consistent reading. I also have different fuel lines because I am running a FASS.
I have a Westac sender/gauge and don't remember anything about mounting vert. in the instructions. I have mine mounted horz. and it seems to work fine. Make sure they send biodiesel compatable hose.
XChris1632X
09-21-2006 09:00 PM
streetsmoker
02-22-2006 06:47 PM
jasonjones
13
02-10-2006 03:25 PM
bigragu
01-24-2006 11:16 AM
DF5152
11-21-2003 06:12 AM
