EDGE COMP- boost fooler setup?
Hello, well when i bought my 2000 dodge dually it has the edge comp in...but the guy wanted it installed safe...so the IP isnt tapped..and its dosent have the little brass elbow off the turbo...my question is can i hook up the other plug-ins that arnt hooked up...run the brass piece...basicly everything but tapp it....will this fool the boost? will i get more boost...or do you not think this is a good idea and i should just tapp it?? thanks
you need that elbow installed or you'r not getting the boost you need to keep you'r egt's in check and the comp will do the boost fooling with or without the elbow hope this helps
kiley
kiley
mx684
13
Jul 24, 2007 07:52 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
