Code Scanner
Old Mar 8, 2007 | 05:52 PM
rimfire1's Avatar
Code Scanner
I was just wondering where I could purchase a code reader,scanner?
I'm not sure what there called, but I need something to read codes to see if my IP is giving any of those bad codes. Thanks in advance
Old Mar 8, 2007 | 06:02 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
PepBoys, Autozone, Kragen, Napa, EBay.......... Take your pick.....
BTW you're looking for a OBD2 scanner/reader
Old Mar 8, 2007 | 06:16 PM
rimfire1's Avatar
Thanks for the info. JPR
Old Mar 8, 2007 | 07:09 PM
phox_mulder's Avatar
Keep in mind, many off the shelf code readers don't handle our dual computer system very well, and won't tell you much more than the key on/off method.
If you have a 98 or 99, then of course, the key on/off method won't work anyway.
phox
Old Mar 8, 2007 | 07:13 PM
JPR Ram's Avatar
phox
True enough... I got mine from Sears for about $150. It not only gives the codes, but give the simple diffenition of each code. It's an Actron, I beleive..
Old Mar 8, 2007 | 07:49 PM
rimfire1's Avatar
So which one do you all recommend? What should I expect to put out on one?
TIA.
Old Mar 8, 2007 | 09:27 PM
JPR Ram's Avatar
TIA.
As for brands, I don't know enough about the different ones. I do like the Actron I have. Look for one that not only says the code, but gives the diffenition and one that will clear the code. I'd think about $100 to $200...
Old Mar 10, 2007 | 06:59 AM
dodgeguy71's Avatar
I had a friend who bought one of the Cornwell truck for around $150-$175 I think and he has used the heck out of it. That way he can find the code and then call me and say....."what's this P0440 mean" and such. Oh what you do for good friends!! Oh yeah and his when reading my 1693/216 would only show the p0216 like it was only reading the ECU but I don't know. It did not show the P1693.
Old Mar 10, 2007 | 02:54 PM
rimfire1's Avatar
Well I got a scanner, and of course the code it brought up was P0216.
Time for a VP44. Guess I am a member now.
Thanks guys for all the help.
Old Mar 10, 2007 | 03:16 PM
Carolinablue's Avatar
Don't know if you guys know about it or not, but on the 2001 Dodge Truck you can turn the ignition switch on, off, on, off three times and the codes will come up in the odometer. You can't clear them or if you can I don't know about it, but if it's throwing a code it will show.
TheMighty'67
May 4, 2008 09:39 PM
Como4076
Jan 18, 2008 09:19 AM
AlCorr
13
Dec 7, 2006 10:28 AM
crobtex
Dec 14, 2005 09:00 AM
dansel
Jan 6, 2004 01:10 AM
