Difference in vp44 pumps?????????
Old Jan 5, 2006 | 11:30 AM
DJD's Avatar
DJD
Hello all I have a newbey Question.Is there a difference between the standard remanufactured vp44 and the hot rod vp44?I pulled my pump last night and it was alot easier than i was expecting,it was out in an hour and five minutes so i can imagine it will take about six hours to replace.
Old Jan 5, 2006 | 11:37 AM
zukgod1's Avatar
About 60-80hp would be the differance. I would get one if I was you. I didnt find out one was available till after I bought a new one...
It took me about 6 hrs I think start to finish tools put away and everything. Not to bad of a job really.
Old Jan 5, 2006 | 12:02 PM
DJD's Avatar
DJD
Thats what i needed to know.Thanks i apreciate it.Do you have a link to someone who sells the hot rod pump or a name of a place?I asked the guys that i was going to take mine to and they said that there was nothing they could do cause it was all electronic.
Old Jan 5, 2006 | 12:18 PM
Shovelhead's Avatar
Administrator / Scooter Bum
One of our site advertisers sells the HR VP.
I purchased mine from Performance Diesel Warehouse.
Old Jan 5, 2006 | 01:33 PM
RickCJ's Avatar
The stock rebuild is rebuilt to stock specs, the Hot pump is built for better performance, I was told some added timing and SO delivery valves and HO pressure. My truck runs with just the pump as good as the Comp on level 3-4!
Easy 70-80 hp gain. The truck idles and runs exactly the same till you drop the hammer.
Old Jan 5, 2006 | 03:10 PM
zukgod1's Avatar
What he said, check the site sponsors.
there are a couple vendors that sell the HRVP.
dan
Old Jan 5, 2006 | 09:04 PM
DJD's Avatar
DJD
Perfect i talked to the guys at performance diesel warehouse and they were great.I am going with the hot rod vp and a different lift pump that they advised.
Old Jan 5, 2006 | 11:37 PM
malojeer's Avatar
is there a difference in fuel milage between the stock and hot rod pumps?
Old Jan 6, 2006 | 08:17 AM
RickCJ's Avatar
Fuel mileage!!! If your stock truck only runs 40 up a hill and you install a performance box and now can run 80 up the same hill, you will get less fuel mileage!!! But if you still go up that same hill 40 with the box on you will get the same or maybe a little better, because the box has a timing increase.
Old Jan 6, 2006 | 10:29 AM
Big Deezul's Avatar
yeah Doug is a huge help. I would make sure you had a good LP as well. I just got my hrvp from him. My truck does sound different though then before?? No clue why and nothing bad. It idles smooth as glass now. It is an awesome power gain.
Old Jan 6, 2006 | 11:20 AM
BobQ's Avatar
How does it compare to a banks power pack? if any one knows, that is all I can compare it to.
Bob
Old Jan 6, 2006 | 01:06 PM
Big Deezul's Avatar
how muchpower does that add? I can say it adds more oomph then my rv275's did
Old Jan 6, 2006 | 02:37 PM
DJD's Avatar
DJD
Ya he said that he had a lp that he advised i used that he sells.We also talked about other lp options and fuel line options that would probably help.Funny,it turns out that these arent much different than any other high performance deal to mess with.How many other people are running an aeromotive a1000 pump?I have one that i am thinking about installing instead of useing the standard lp desighn.also thinking about getting rid of the banjo fittings and replace with AN fittings.
D2 Cat
Aug 12, 2009 07:57 AM
dieselman83
Sep 23, 2008 11:36 PM
MikeThomas
Jan 20, 2008 11:13 AM
Ilikebikes
Dec 11, 2006 10:13 PM
Flatty
14
Nov 15, 2005 12:03 PM
