difference between carter and campaign lift pump
Old Aug 28, 2007 | 01:49 PM
SSweeney's Avatar
Is one better quality then the other?
Old Aug 28, 2007 | 03:08 PM
hamilton71801's Avatar
I put on a campaign pump and the press. was lower than the carter pump. I think I only got @15,000 miles out of it too but that could just be the luck of the draw cause I've heard people praising the campaign pumps.
Old Aug 29, 2007 | 07:42 AM
Joe Diesel's Avatar
my campaign pump just went on me last 2 weeks idle @ 6 so I'm gonna send it back to Cummins and see what I can get out of it, this one lasted 7months and its relocated with the vulcan ... at least I can change it in 15mins
Old Aug 29, 2007 | 04:53 PM
qwest's Avatar
relocated campaign pump:
20K miles , 15 months, Low fuel pressure in hot weather...
Old Aug 29, 2007 | 07:30 PM
SSweeney's Avatar
so the campaign is no better. I just dont get it. Is it that hard for dodge cummins to make something reliable other than the cummins block? Anyway, I guess the carter is just as good?
Old Aug 29, 2007 | 07:38 PM
RickCJ's Avatar
The pumps are the same! the campaign is just cheaper with a fuel pressure light! Carters way of trying to make it right. Cummins doesn't make Carter pumps! Cummins doesn't make Bosch VP44 either!
Old Aug 30, 2007 | 07:10 AM
Joe Diesel's Avatar
but you figure Cummins wouldnt want low end parts on or running there engines
Old Sep 2, 2007 | 06:11 PM
dieseldemon's Avatar
I have installed a bunch of the campaign pumps and have not had any problems with them.
Old Sep 2, 2007 | 11:16 PM
johnh's Avatar
the difference is the vp will suck fuel thru the campaign pump when it fails and it won't with a oem carter
Old Sep 3, 2007 | 08:16 AM
m.rehme's Avatar
I only replaced 1 pump in 313,000 miles I installed a Carter purchased from O'Rilleys that carries a lifetime warranty.
Old Sep 3, 2007 | 09:00 AM
"Limited Lifetime Warranty". I took my "lifetime warranty" Carter back to Oriellys and yes, the first one is lifetime. Everyone after that is 1 year so be sure that the new ones fail at least once a year.
Old Sep 3, 2007 | 01:03 PM
qwest's Avatar
anyone take the plate of a campaign pump,
Pulled mine off, can't figure out how it works, or which way it turns,
the vanes don't seem to extend, ? centrifugal force ?
Also the vane shaft (holds the vanes ) was rubbing against bottom plate,
meta to metal wear. not really impressed,
Yes, I agree, crap parts on a great engine.
? what type of lift pump on other equipment with a cummins and a vp44 ???
Old Sep 3, 2007 | 01:09 PM
johnh's Avatar
some applications don't use a lift pump
305motorsgt
Apr 27, 2014 08:17 AM
supr
34
Nov 2, 2010 04:45 PM
yamarx1
Feb 13, 2009 10:37 AM
wesgib
19
Dec 20, 2006 01:31 PM
dingoe
26
Nov 12, 2006 11:28 PM
